Go to Post Being Wrong Late is the number one killer of FIRST aspirations. - Joe Johnson [more]
Unread 19-03-2010, 20:04
Re: Are COTS shop vacs legal? They have motors
Originally Posted by jamie_1930 View Post
In that case, this is the man to talk to
Al Skierkiewicz
I happen to be an inspector, though not a lead inspector. Yes, I did pass the certification test.
Al is one of the people I was thinking of when I wrote that post. Dave Brinza (LRI at Los Angeles) was another.
Unread 19-03-2010, 20:18
Here's a related Q&A:
http://forums.usfirst.org/showthread.php?t=13981
It addresses COTS clutches, but the GDC makes it clear that while the COTS part is legal, if it uses any non-Kit motors, those are not-legal.
Unread 19-03-2010, 20:23
There are a couple of others, as well.
http://forums.usfirst.org/showthread.php?t=14498
http://forums.usfirst.org/showthread.php?t=13928 (Note on this one: I think that if you made it work using only KOP motor(s), it would be legal, but because that wasn't specified in the question, it was declared not legal.)
Unread 21-03-2010, 00:00
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
I'm not the LRI at your regional, I'll be at the one across the street that weekend...
However, in spite of the fact that "Nothing on CD is official", I can assure you that a shop vac with the original factory motor, will not pass inspection. It has to have the motor replaced with a motor that came in the kit of parts.
If you would like more confirmation, send me a PM and I will get in touch with you.
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
Unread 21-03-2010, 00:38
Ramiro_T's Avatar
Ramiro_T Ramiro_T is offline
Technical Specialist
AKA: Ramiro Trejo
no team (n/a)
Team Role: Student
Ramiro_T is an unknown quantity at this point
COTS are considered illegal since there was never any in the kit. It's like trying to use last year's globe motor this year. I suggest you replace those with a fisher price moto.For our robot, we took these little mounts from an ROV rotor and retro fitted everything to work. Always read the manual.
Unread 21-03-2010, 17:25
RoboMaster's Avatar
RoboMaster RoboMaster is offline
Alum, former programmer&co-captain
FRC #2472 (The Centurions)
RoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant future
Ok, so I notified my team and we realized that it wasn't legal. Apparently the people I talked to looked at this thread that I sent them or had realized beforehand it wouldn't work. We are going to see if we can get it to work a different way. Thanks for all the suggestions and discussing this with us.
My engineering blog: noeticbrainwaves.blogspot.com
I'm not slacking, my code's compiling
...and I'm using LabVIEW
Unread 21-03-2010, 19:44
Thanks for the confidence but Eric is pretty much on for his postings of the rules and Jeff is a right hand man and division LRI. I also will be at your regional helping out. WildStang is currently using two vacuum blowers coupled to FP motors in the exact duty you describe.
Unread 21-03-2010, 19:52
LLogan LLogan is offline
Head Screw Tightener/Cheerleader
AKA: Logan
FRC #1261 (Robolions)
LLogan has a spectacular aura aboutLLogan has a spectacular aura about
My team gutted a handheld vacuum and replaced the motor inside with a fisher price. It's basically just an enclosed impeller assembly on the inside. The most difficult part was replacing the motor. The impeller was pressed onto the shaft of the old vacuum motor, so we had to cut the shaft of the old motor and press the impeller onto the shaft of our fisher price.
We showed the inspector pictures (that prominently displayed the fisher price's serial numbers) of the process and we were good to go.
How to attach Bevel Gears to shaft when they are not keyed or have set screws Creator Mat Technical Discussion 11 01-02-2010 01:27
Trailer Tongue? Are they COTS? neoshaakti Kit & Additional Hardware 5 09-01-2009 17:51
Have You Attended Multiple High Schools? Do They Have FIRST Teams? KathieK General Forum 25 08-01-2009 02:16
Does anyone have previous year's gearboxes they are not using? VEN General Forum 2 29-01-2007 17:32
Are these wheels available, anf if not are they ever gonna be? Elgin Clock FIRST Tech Challenge 3 12-11-2005 22:27
