Go to Post Hurricane season would be torture, at least in snow you can lock the doors and know the robot is safe. - ATannahill [more]
  #46   Spotlight this post!
Unread 21-03-2010, 18:10
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
Re: Power Management Recommendation for driver stations
Originally Posted by Damaku250 View Post
One of our team members has an uninterruptable power source: http://www.tigerdirect.ca/applicatio...2224&CatId=234
Would we be able to use this on the field to power the laptop?
Not sure if you'd want to carry the heavy thing around, especially on the field where it could be dropped accidentally.
-Tanner
  #47   Spotlight this post!
Unread 21-03-2010, 18:32
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
As long as it is declared part of the operator console, fits on the shelf, and is safe, there are no rules prohibiting this.
  #48   Spotlight this post!
Unread 21-03-2010, 18:37
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
Somebody correct me if I'm wrong, but I definitely didn't see any power strips in the queuing area at the Midwest regional as Bill's Blog indicated there would be.
I know the announcer asked at the start of elims for any non-elim teams with charged Classmate batteries that they were willing to share to bring them over.
  #49   Spotlight this post!
Unread 21-03-2010, 18:46
Craig,
That is an overkill and is very heavy.
  #50   Spotlight this post!
Unread 21-03-2010, 18:55
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Agree with Al, it is an overkill to have on the drivers station. However, since you do have it, I would recommend you put it on your cart and have run off of battery power during matches if there are 1. no power at stations for a tournament or 2. no smaller universal battery purchased by your team.
1058 PVC Pirates 2016 - xxxx
  #51   Spotlight this post!
Unread 21-03-2010, 19:44
Damaku250's Avatar
Damaku250 Damaku250 is offline
Electromechaneumatics guy
AKA: Craig Hoo
FRC #3161 (H.T. Tronic Titans)
Team Role: Electrical
Damaku250 is an unknown quantity at this point
scratch that, we'll probably get one of the things from the link in sanddrag's signature and use a power inverter...
-Rookie All Star Award [WAT Regional 2010]
Electrical/Control systems, Mechanical and Pneumatics teams, Human player
  #52   Spotlight this post!
Unread 21-03-2010, 21:53
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Originally Posted by The Lucas View Post
If you are using the PSoC board make sure to unplug it between matches, it's a real powerhog. At Chesapeake Regional, our Classmate was charged going into Elims. By SF 1-2 our Classmate battery was in the red and the PSoC was failing to connect (so we stopped using it). In SF 1-4 (a back to back match), the battery was very low and may have contributed to periodic network communication error. We would run for about 10sec then lose communication for about 2 sec (not sure the Classmate was the problem but since we didnt play a match afterward, it remains a possibility). Back in the pits the PSoc wouldn't work till I plugged the Classmate in. I couldn't reproduce the communication errors while tethered.
really? That would explain why we could only get about a 5% charge between matches. Will try disconnecting it during philly
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
  #53   Spotlight this post!
Unread 21-03-2010, 22:04
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
AndyMark is carrying an inverter with an Anderson connector.
We are using one that is similar, and we keep the classmate plugged in to it while we are waiting in the que.
I do know of one team that borrowed it to keep their laptop plugged in during a match, because their battery was almost gone. It was allowed at their player station.
I have not seen outlets at the player station or nearby at KC or BMR.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
  #54   Spotlight this post!
Unread 21-03-2010, 22:49
AKA: Dr. Brooks
no team (WRRF)
We used a dc-dc laptop charger with an anderson connector on it
at SVR. The one problem we did have was that our 110 volt classmate
charger died on Friday, we would have been up a creek without the dc-dc
charger. We used it to charge the laptop overnight on Friday night,
putting a fresh battery on it when we left the pits at 6pm. We then
used it all day on Saturday. It worked out well for us.
The 20 volt, 3.7 amp charger with the 5.5mm-2.5mm plug at
www.powerstream.com is ED1075-52. RadioShack
has a very cheap universal one with lots of plugs and adjustable
voltage, but you will have to check the plugs it has for a proper
fit.
Eugene
  #55   Spotlight this post!
Unread 21-03-2010, 22:51
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
How do the classmate ac-dc converters work? are they just rectifier diodes? Is there anything preventing them from being used as dc to dc converters? {such as issues with the rectifiers releasing 'magic smoke'}
  #56   Spotlight this post!
Unread 21-03-2010, 23:06
AKA: Dr. Brooks
no team (WRRF)
We will have take our dead classmate charger apart to see what is
in there. Even if it is a switched supply that can run on dc, hacking
together a high voltage dc power supply is a really bad idea that our
UL safety inspectors should frown on. Spend $20 at radio shack for
a suitable 12 volt charger!
Eugene
  #57   Spotlight this post!
Unread 22-03-2010, 13:36
CrazyCarl461's Avatar
CrazyCarl461 CrazyCarl461 is offline
Power User
AKA: Carl Agnew
CrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant future
Send a message via AIM to CrazyCarl461
461 is the team that had to borrow the inverter from AndyMark. We had the second match of the day and arrived to a completely dead classmate in our pit. It worked great and we bought it on the spot. Thanks Andy!
Get one for yourself
My 2011 Build Season Blog
Resistance may be futile, but capacitance has potential!
© All content is protected by the honor system
  #58   Spotlight this post!
Unread 22-03-2010, 13:52
JoshD's Avatar
JoshD JoshD is offline
FRC #0975 (Synergy)
JoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to beholdJoshD is a splendid one to behold
Send a message via AIM to JoshD Send a message via MSN to JoshD
Our guys went the inverter route, except they wired it up themselves and they stored the battery on the control board. It's crazy, but it works, we never had an issue with the Classmate, at least to my knowledge.
  #59   Spotlight this post!
Unread 22-03-2010, 15:15
Eugene
Eugene,
I am betting that the cable is broken as it leaves the wall wart. I will be very interested in knowing the outcome.
  #60   Spotlight this post!
Unread 22-03-2010, 15:22
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
If you're coming to the NU CT regional, Rosie will be bringing our UPS's for use at the field drivers stations, if needed by teams. We did it at WPI and Kate (the FTA) thought is was a great idea!
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Laptop recommendation for inventor/pro/e/etc Zyrano CAD 6 28-01-2010 23:20
"vertran" teams not getting the new driver stations?!?! BEEKMAN FRC Control System 6 06-11-2009 20:10
Power Driver Station with Serial pyr0b0y Technical Discussion 6 30-04-2009 19:53
Power for Driver Station mutantblond Technical Discussion 26 11-03-2009 01:20
Laptop for FRC Labview: Recommendation Wanted Foster National Instruments LabVIEW and Data Acquisition 2 22-11-2008 21:14
