Go to Post I'm really impressed with how much effort we'll go to, to avoid buying a $25 servo tester. - MrForbes [more]
Unread 21-03-2010, 22:42
keericks's Avatar
keericks keericks is offline
AKA: Kent
FRC #1671 (Buchanan Bird Brains)
keericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of light
What connects to the field mgmt system?
Is just an Ethernet connection ... And maybe ac power if the the regional provides? Trying to construct a convenient driver console and want to make sure those connection ports are easily accessible. Thanks.
Unread 21-03-2010, 22:45
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: What connects to the field mgmt system?
All that plugs in from the field is an Ethernet cable to the Classmate.
Having said that, it would be wise to leave all the ports we use on the Classmate (ethernet, power, and USB) easily accessible.
Unread 21-03-2010, 23:14
keericks's Avatar
AKA: Kent
Do we provide the cable or does the station have a cable that we plug into the port on the classmate?
Unread 21-03-2010, 23:17
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
The cable will be there on the driver station shelf for you to plug into your Classmate.
Unread 21-03-2010, 23:53
You'll want to be able to easily unplug the e-stop button when you're on the field, but be able to plug it in when in the pits.
What should go under the field? ShadowNinja General Forum 3 10-01-2009 11:57
What is the field of view (FOV) of the default lens? Jared Russell Programming 7 26-01-2006 21:54
What colors are used on the field auditt241 Programming 6 03-02-2005 18:41
What is the true field infrared emitter? scottm87 Programming 4 20-04-2004 18:22
So does anyone know what the name of the new field archiver 2001 4 24-06-2002 03:01
