Go to Post It is a wise tutor/mentor who knows when to ask for help. - JaneYoung [more]
Unread 21-03-2010, 17:05
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Adding a PWM/Jag causes a -63195 error
We have a robot with 8 motors and they all work. We added a 9th PWM and when we do we get an -63195 error. Digitial interface is in Slot 4 and we've tried both ports 9 and 10 on the digitial sidecar.
Google searching didn't return anything of use. A CD search came up with a team that was having general comm problems, which is not our issue.
Another team reported problems with power to the digital side car. The other motors on the DSC work, so I don't think it's a power issue.
We did a reinstall of the firmware with no positive results.
I'm looking for any good ideas on what to try next.
Thanks!
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 21-03-2010, 17:30
Re: Adding a PWM/Jag causes a -63195 error
I would guess that it occurs due to a duplicate PWM Open (two Opens of PWM 9 for instance). I suppose that a mistyped refnum name might result in this error, but I don't think so.
Unread 22-03-2010, 09:56
We've looked in the code for that and are not coming up with a duplicate entry.
I've posted this problem on the FIRST forums, is there another place to ask? (I get the impression that the NI forums are for standard configs, not the FIRST setup.
Unread 22-03-2010, 11:41
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Would you mind posting a zip file of the code? If that's too public for you, you can e-mail it and I can have a look.
Unread 22-03-2010, 18:25
Update -
We moved a working motor to PWM 9 and it works (so the sidecar is good, interface board and cable is good)
We created a new PWM on another digital side car/DIO interface. No change
Moved VI's to a brand new, clean project, no change.
v89 Jag used for CAN, trouble going back to PWM? heydowns CAN 6 18-03-2010 11:11
Jag vs. Dr. Pepper SodaFail Electrical 17 09-02-2010 03:57
Compressor Code causes No Robot Code Error sircedric4 C/C++ 25 03-02-2010 10:13
Encoder causes 24 bit relocation error pafwl C/C++ 3 28-01-2010 08:53
4 pin EDU PWM out power, red pin2 V in error Dale(294engr] Electrical 4 13-02-2004 03:03
