Go to Post FIRST describes this program as students working "side by side" with professional mentors. We describe our team as working "shoulder to shoulder." Maximum learning happens with maximum interaction between students and mentors, whenever and wherever that may be. - jspatz1 [more]
Unread 22-03-2010, 17:36
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: XBOX Controller Triggers is an axis but which one?
Originally Posted by Bmcdonnell View Post
Go to control panel --> game controllers --> properties. It shows up what button and axis is what when you press it. We have everything except the rumble. There's some threads, I believe in WindRiver, for using rumble, but does any one know how to do it in Labview? I would love to be able to have it rumble when our robot senses a ball.+
I remember seeing those threads, and you have two options (assuming I remember correctly): write your own xbox driver for windows, OR, open the xbox controller, find the rumble wire, and wire it to a digital out on the cypress board.
the default code and the DS software prevent writes to the joystick, so you would have to circumvent it using one of the methods above
Watchdog.Kill();
Unread 22-03-2010, 19:36
JohnFogarty's Avatar
AKA: @doctorfogarty
Thanks for all your help I hope to try this out at Palmetto.
Just another quick Question. when I wired axis 3 into a True False Selector the true and False changed to 1 and 0 which i put my true code in 1, and my false code in 0. see attached pictures tell me if im doing this right. If the button is true then set the motor speed to the percentage of the button press, for variable control. If the button i...s false, then I made another true/false case for the sensor. In the false case, I set the motor speed to 0.1. In the true case, I set the motor speed to 0.
This way, when the button is NOT being hit, it looks for the sensor, and it spins it around REALLY SLOWLY until the sensor is tripped, and then it stops there.
and another
John Fogarty
Unread 22-03-2010, 20:48
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
I would recommend that you delete the wire from axis 3 and change your case structure back to TRUE and FALSE. Test axis three against "> 0.5" and if it's greater than 0.5, it will tigger the TRUE case, and if it's less than 0.5 it will trigger FALSE.
The problem with using the 0 and 1 cases is that it is possible that you cannot get to the 1 case if your XBox controller is out of calibration. If you use the 0.5 compare, you will be covered.
Unread 30-06-2010, 13:46
MCeGEAR MCeGEAR is offline
FRC #1243
MCeGEAR is an unknown quantity at this point
There are Drivers, non-Microsoft, that support the rumble packs, you just have to risk the viruses and spend some time looking.
Unread 30-06-2010, 13:58
Zme Zme is offline
FRC #2619
Zme is on a distinguished road
for a controller mapping of the xbox 360 controllers please see this post
http://www.chiefdelphi.com/forums/sh...3&postcount=12
Xbox Controller Team1710 FRC Control System 9 30-06-2010 13:17
Which axis for accelerometer? bitsoglass NI LabVIEW 1 23-01-2009 17:42
Xbox Controller? ScottieDo555 Technical Discussion 24 29-01-2008 16:24
Which is better? (Xbox 360 or PS3) 842.001 Games/Trivia 29 11-11-2006 16:06
Do the Dew... but which one? OneAngryDaisy Chit-Chat 13 16-06-2003 16:17
