Go to Post Excited and motivated students and teachers can do amazing things. - Wetzel [more]
Unread 22-03-2010, 18:42
Lyconn Lyconn is offline
Lyconn is an unknown quantity at this point
Solenoid & Motor Controlling
Hello all,
I'm a very novice user of labview (mech. eng. major so i usually avoid programming) so bear with me on the necessary information. I have been tasked with creating a VERY SIMPLE block diagram in order to control 1 motor (forward and reverse required) as well as 3 solenoids that will be fired at different times. I've looked over previous posts regarding solenoid control (which is what I'd trying to start with) and can honestly say I don't know where to begin.
Basically the project I'm working on has the motor driving a slider mechanism which passes above a substrate. During each pass of the 3-pass cycle a different solenoid needs to be open to spray our pressurized solution onto the surface of the substrate. The user will simply enter how many total cycles (3-passes per cycle) they desire, no graphs or data needs to be collected at all. Any guidance on how to get started, at the very least, would be greatly appreciated. Thanks in advance.
Unread 22-03-2010, 19:28
Electrical Engineer
Rookie Year: 1995
Re: Solenoid & Motor Controlling
This forum is for the FIRST robotics competition (high school) and not a general robotics NI forum. I'm not sure that you will get the answers you seek here.
Mike Betts
As easy as 355/113...
Unread 22-03-2010, 20:21
my mistake, thanks for the clarification
Controlling motor speed WGRAY Programming 9 16-02-2009 22:50
Laptop Controlling a Motor popo308 NI LabVIEW 4 08-02-2009 14:16
5 Amp Fuses for Analog Breakout & Solenoid Breakout finman Electrical 3 10-12-2008 11:59
Legality of controlling 2 cylinders with 1 solenoid mtangolics Pneumatics 4 19-02-2004 21:29
Q&A Discuss: Cylinders + Solenoid valves CD47-Bot Extra Discussion 1 05-02-2003 17:21
