Go to Post I walk through the door, and suddenly the field breaks down. It must be my magnetic personality. - Swan217 [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 22-03-2010, 23:52
blayde5's Avatar
blayde5 blayde5 is offline
AKA: Abhi
FRC #3504 (Girls of Steel)
blayde5 is a glorious beacon of lightblayde5 is a glorious beacon of lightblayde5 is a glorious beacon of lightblayde5 is a glorious beacon of lightblayde5 is a glorious beacon of light
AndyMark Plaction Wheels
http://www.andymark.biz/am-0514.html
My team has started using these wheels this year and for the most part we get good performance out of them.
However we've noticed that AndyMark joins the treads with staples. During both of our competitions we've found the treads to start coming off and during one of our matches at SVR, the tread actually did come off.
To solve it we just riveted the ends of the tread and it seems to work okay.
Any other teams using these wheels have the same issue?
Unread 22-03-2010, 23:53
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: AndyMark Plaction Wheels
Pretty much all the teams I've talked to have the same issue.
They use one of two solutions:
1. More, bigger staples to keep the ends together
2. Rivet the tread to the wheel.
Unread 22-03-2010, 23:55
Chris is me's Avatar
AKA: Pinecone
This happened to us too. I kinda expected it to happen. Riveting on the tread was one of those things we kept putting on the list of things to do, but never did.
Two rivets per wheel did the trick. Everyone should do this always.
Unread 22-03-2010, 23:57
Edoc'sil's Avatar
Edoc'sil Edoc'sil is offline
FRC #2531
Edoc'sil has a spectacular aura aboutEdoc'sil has a spectacular aura about
if it comes off at a competition a drill and a zip tie does the trick as well too.
Here lies a toppled god-
His fall was not a small one.
We did but build his pedestal,
A narrow and a tall one.
Unread 22-03-2010, 23:59
Jamie Kalb Jamie Kalb is offline
Jamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to all
This happened to us, too. Same issue, same solution.
Team 3129 Green MacHHHHine Founder, Captain (2009-10), Alumnus, and Mentor (2011-14)
2011-13 VEX World Championship...
Unread 23-03-2010, 00:00
AKA: Pinecone
If you're already drilling the hole, why not rivet it? If you need a hand pop rivet gun, you can borrow my team's gun.
Unread 23-03-2010, 00:37
AKA: Dr. Brooks
no team (WRRF)
We had the treads come off during light testing just prior to ship.
We riveted, but the treads came loose again.
We solved the problem with a method identical to how
we used to make good wheels from KOP wheels. We cut
the flanges off and then sanded the rims using a belt sander
right on the robot. We usually use a lathe for this, but we
did not want to take 8 wheels off the robot at this point.
We made our own treads using incline belting from McMaster,
by carefully sanding the first layer of nylon off the backing,
just exposing the black rubber layer. We then cut the treads
and glued them on the wheels with mid-cure crazy glue, using
no rivets or screws, after cleaning the tread and the rim with
MEK (or acetone if you don't have MEK handy).
No tread came loose at SVR. When we rip a tread off of one
of these wheels, it leaves the black rubber from the tread on
the wheel rim all the way around. Screws or rivets are not
needed at all when using this gluing procedure. In the rare
event that a tread does start to peel we use some glue on
it and it rarely starts to peel again.
Eugene
Unread 23-03-2010, 01:43
mahumnut's Avatar
mahumnut mahumnut is offline
FRC #1418 (Vae Victus)
mahumnut is an unknown quantity at this point
our team trimmed the tread itself because it was overlapping the raised edges of the wheel, we then used rivets. After the DC regional, we ordered their aluminum version because the plastic ones kept on breaking when our robot went over the hump. Because our robot was 6 wheeled, the hump wasn't the smoothest trip crossing the zones.
Unread 23-03-2010, 02:33
SteveGarward's Avatar
SteveGarward SteveGarward is offline
Red 5, standing by...
AKA: 7 years already
FRC #0111 (WildStang), FRC #3132 (Thunder Down Under)
SteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud of
We hit this issue in the hour before shipping the robot. (We also sheared the bolts off one of the drive wheels and noticed the other drive wheels bolts were bent, but that's another story...).
We tried holding it on with tape just so we could practise prior to shipping, but it kept slipping out.
We had some spare wheels, so we changed them out at GSR prior to competition. These lasted a while (I think we were being careful) but by the end of Friday we had lot a tread again. We got it back together for Saturday, but lost the tread again in the next match.
Prior to crating it ready for Atlanta, we managed to get a couple of wheels ready, using contact glue on the tread AND rivets. Hopefully this will hold. Otherwise I'll either cry or just go home.
Ok, maybe not.. it's a long flight..
FRC Team 111 - WildStang (Mentor, Drive Coach)
FTC Team 7458 - Full Force! (Mentor, Coach)
FRC Team 3132 - Australia's FIRST FRC Team! (Holy crazy first year, Batman!)
Unread 23-03-2010, 06:54
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
When you add screws or rivets, be sure to make them slightly off of the centerline of the wheel.
These wheels are molded plastic, and the seam is right in the center. By moving slightly off to each side, you are staying in stronger material.
Advice straight from the "manufacturer", so to speak.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 23-03-2010, 07:22
Jared Russell's Avatar
Taking a year (mostly) off
Same problem; same solution.
Unread 23-03-2010, 07:28
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Our Plaction wheels still have the standard staples from AM in them, and we haven't had any problems with them... yet.
*Scrambles to pack Rivet Gun and Rivets for next event*
-Dustin Benedict
Unread 23-03-2010, 08:04
45Auto's Avatar
45Auto 45Auto is offline
FRC #2992
45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future
Obviously not many people on this thread read the AndyMark page on the Plaction wheels here:
http://andymark.biz/plactionwheel.html
Quote from the page:
Roughtop or Wedgetop conveyor belt material are used as replaceable treads on these wheels. For best use, install rivets into each end of the tread to insure the tread stays put under heavy usage.
First thing we did upon taking ours out of the box was to rivet the ends of the tread. Although we managed to break all of the bolts holding the sprocket onto one of the wheels in the semi-finals at the Bayou Regional, the wheel survived and we never had any problems with the tread.
Bayou Regional Champions with 1462 and 3362 - See you in Atlanta!
Unread 23-03-2010, 08:58
MarkoRamius1086's Avatar
MarkoRamius1086 MarkoRamius1086 is offline
Robot Inspector
AKA: "Petrie"
FRC #1086 (Blue Cheese)
MarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to behold
Those are amazing wheels! The traction and quality is superb, but ugh... We had the same problem with one of our wheels in the second to last match of the finals! We were going over the bump... and all of a sudden it stalled! You can see it on the youtube video... when we started over the bump the back tread came right off. I dont know if there is a channel that it popped out of... I didnt get a good look at it before we shipped it off. All I know is the moment our driver backed off of the bump, we had a tread lying on the field.
Seeing this thread I am certain we shall replace the stripped wheel with one from our prototype and then pop rivet all of them before the matches at NC. Has anyone pop-riveted the plaction wheels and has advice that could prove useful or critical? I saw the great post on not riveting on the centerline, thank you for that, but does anything else come up?
HEROES DIE, BUT LEGENDS LIVE FOREVER!
Unread 23-03-2010, 09:06
Just make sure that the rivets you use are long enough to clear all of the way through the plastic.
Plaction and Omni wheels Edoc'sil Technical Discussion 7 21-02-2010 12:20
AndyMark Plaction Wheels Diserasta Technical Discussion 1 17-01-2010 22:20
Plaction Wheels : 250 Spacers/Review Ice Berg General Forum 2 17-01-2010 11:26
AndyMark Wheels Andy Grady Inventor 2 05-02-2007 16:49
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
