Go to Post Geez, now I'm like some all-knowing all-seeing FIRST sage who lives in the moutains waiting for students to venture upwards to my home to ask me if there will ever be a water game....:rolleyes: - Koko Ed [more]
Unread 23-03-2010, 08:32
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
Inverting controls in Java
Hi,
Unfortunately, I'm not the programmer for my team, but I did pretty much all of our programming when we were using C. This means that I don't know the Java lingo either. So please bare with me.
What we're trying to do is invert our controls so that we can flip the forward and reverse directions on our robot. This is so that we dont need to turn the robot around to herd balls and stuff. Our programmer said that there is an "invert controls" option, but when she uses it, the axes of the joystick switch.
Has anyone found an easy way to invert the controls for their robot? We're using the out of the box tankdrive routine.
Thanks,
Windell
Unread 23-03-2010, 08:41
Jared Russell's Avatar
Taking a year (mostly) off
Re: Inverting controls in Java
RobotDrive myDrive = new RobotDrive(1,2,3,4);
if( invertMyDrive == true )
 myDrive.setInvertedMotor(kFrontLeft, true);
 myDrive.setInvertedMotor(kFrontRight, true);
 myDrive.setInvertedMotor(kRearLeft, true);
 myDrive.setInvertedMotor(kRearRight, true);
myDrive.tankDrive(leftStick, rightStick);
The above snippet will reverse the forward/backward direction of your bot if the "invertMyDrive" variable (a boolean) is set.
It sounds like if your axes got switched, you only inverted half of the drive.
Unread 23-03-2010, 08:47
FRC #2477
really appreciate it Jared. I'll pass this on to our programmer!
Unread 24-03-2010, 01:27
Geek 2.0 Geek 2.0 is offline
FRC #0107
Geek 2.0 will become famous soon enough
You might want an "else" portion in there too to set the back to normal. It's nice to be able to change, but it's nicer to be able to change back
Unread 24-03-2010, 07:35
Details, details
Problems Inverting Wheels? Must Be Drama NI LabVIEW 1 15-02-2010 17:41
**FIRST EMAIL**/Java and Orbit Balls *****JAVA DISCUSSION*** Pjohn1959 Programming 37 31-08-2009 15:55
Inverting x-axis jkjohnson Control System 8 22-02-2007 02:24
Inverting Joysticks? The yellowdart Programming 5 20-02-2006 20:05
Inverting Y axis on joystick FormatteD_C Programming 7 24-02-2004 16:56
