Go to Post I urge them to build the kitbot and repeateadly smash it into a concrete wall in order to sate their anger. It will soon wane when they manage to do more damage to the wall than to the kitbot. That is honestly the reason that we ended up using the kitframe this year. - Andrew Blair [more]
Unread 23-03-2010, 13:57
Ryutso Ryutso is offline
Modularity, modularity, modularity
AKA: Toby Cubbin
FRC #0108 (Sigmac@ts)
Ryutso is an unknown quantity at this point
Classmate questions
Our classmate has a couple things wrong with it that are more annoyances than actual problems, but they're annoying enough to want to fix:
1. Our classmate automatically logs into the Driver account on start up from a full shutdown. What should we change to stop that from happening?
2. When we log out of (not "Switch Users") the developer account, it goes to a black screen and doesn't respond.
Also, there's nothing in the rules about this, but we were hoping to upgrade the classmates RAM to 2GB before the championship so we can get faster code deployment and quicker boot times. Has anyone done this successfully or is this not legal?
Unread 23-03-2010, 14:55
Re: Classmate questions
Change nothing. That is the desired behavior.
If you want to log into the Developer account on startup, hold down the Shift key to force the system to present the login screen instead of automatically logging in as Driver.
That is a problem. You should probably restore the Classmate to its original state using the provided "RESTORATION KEY" flash drive (and then apply the latest LabVIEW and Driver Station updates). If you've been using the Classmate for software development, make sure you have saved all your work on an external disk or flash drive first!
There is something in the rules about it. <R60> prohibits any modification of the Classmate PC, with the exception of part A: "User programmable “dashboard” code in the Classmate PC may be customized." and parts I: "Fasteners may be used to attach the device to the OPERATOR CONSOLE or ROBOT." and J: "Labeling may be applied to indicate device purpose, connectivity, functional performance, etc."
Unread 01-04-2010, 22:15
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
technically, it's not a modification, the ram could be considered a separate device, therefore, you are not modifying the class mate, but the RAM
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 02-04-2010, 00:57
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Will the Classmate run without RAM? Don't cause stress for your team and your inspectors by doing this.
Q&A it if you think there is any chance it would be ruled legal.
Classmate Problems hunter7193 Control System 5 07-02-2010 16:44
Classmate wireless darkorbit Control System 2 06-02-2010 22:50
Classmate PC lon.bushweiler Control System 8 22-01-2010 14:46
Classmate MachineSMMC NI LabVIEW 10 15-01-2010 13:47
Bumper Zone Questions (was Misc. Questions) viperred396 General Forum 9 10-01-2010 12:09
