Go to Post I've be addicted for 15 years. Tried to quit but failed. - Gdeaver [more]
Unread 23-03-2010, 15:29
Thomas Clark Thomas Clark is offline
Hacker
FRC #0237
Thomas Clark is infamous around these parts
Re: Driver station coding and other
Originally Posted by codedr View Post
Building a cross environment on Linux would require
- build a ppc cross compiler for x86 linux
GCC was ported to Linux almost twenty years ago. It can be easily targeted to vxWorks PPC.
- integrate and test compiler in eclipse
Not really. Eclipse already runs on Linux as well.
- test the method for downloading the code to robot
FTP on a normal non-VPN connection. (or non-VLAN or whatever)
versus
- taking the existing wind river environment and deploy
Which required Windows. As I said, not everyone uses Windows.
If you can convince a small group of robo linux enthusiasts to build the
environment, you could grow support for this endeavor.
Good idea. This would be easier, of course, if there were some sort of open specifications on how the virtual terminal monitor thing works. Is it SSH? Telnet? RSH?
In the meantime, I'll try getting GCC and WPIlib to work together on Linux and maybe write a small IDE in PyGTK.
2010 Driver Station Netbook Driver Account and Java joshholat FRC Control System 2 10-01-2010 15:04
Spare router and/or driver station? TD912 FRC Control System 4 28-09-2009 18:04
paper: Set and display your Auto-Mode using LabVIEW and the Driver Station PhilBot Extra Discussion 0 11-02-2009 12:32
Camera and driver station viperred396 General Forum 8 05-02-2009 10:12
