Re: Small FMS timer bug
The reason I asked is that I have just asked our coders to implement an automatic brake feature that puts the brake on our winch with 3 seconds left - I don't like depending on our drivers to remember in the heat of battle if it is easily fixed. From what our coders have been able to discover, there is no "what is the match time" function available on the cRio -- on the Classmate, yes, but not the cRio. So... no problem. We can watch for the first enable after Auton Mode and start counting seconds. When we get to 117, time to throw the brake with 3 seconds to spare... ...except now do we have to wait until 122? Hmmm... Anyone have a more elegant solution? Joe J. Last edited by Joe Johnson : 23-03-2010 at 18:19. |
Make your driver do 100 pushups every time he forgets.
-John |
You've been spending too much time around Paul...
Anyways, this is an interesting issue... never considered that time would be off... Its curious how (supposedly) this bug was introduced in 2009, and not detected until now. As has already been stated, maybe the best route at this point is to let this bug live its life for the remainder of this year, and kill it next year. |
This is very interesting. I know that a problem similar to this existed in 2004 as I personally timed matches at the CT regional in Hartford that year.
The 2004 peoblem seems to have been a bit worse as each match was an unperdictable length (some longer and some shorter than 2 minutes, with some off by as many as 12 seconds!) I would say that if the timing is off in a consistent manner this is less of a problem that is matches have inconsistent length. I wonder how the FMS calculates time...(not a programmer so that may be a rhetorical question...) Rob |
Incorrectly.
If it's always a consistent extra 5 seconds, I have no problem with it. It gives the students 5 more seconds of play each match and maybe win.
#7
I don't know if this is unrelated or not, but when you start a practice match on the Classmate, about 5 seconds (just remembering here) is elapsed before it enables the robot for autonomous.
#8
They are probably not related because the DS practice mode was written without knowledge of or access to the code of the FMS. The practice mode defaults to having a five second countdown -- the DS ticks down the seconds, before it starts the sound effect and the auto period.
Is that the five seconds you are commenting on? If so, you can change it in the setup tab. Greg McKaskle |
#9
Yes it is, thanks Greg.
#10
#11
Definitely let someone at FIRST know about this one -- post it to the official forums.
Greg McKaskle |
#13
I know if you are using labview you can return an elapsed teleoperated time as a variable (which may be more "official") you can reference in your code. I don't know if it is the same for C++ and Java but you should look into it. |
#14
The LV framework computes the time the same way as mentioned. It counts from the first Tele packet received.
Greg McKaskle |
#15
This is very interesting. I will time some matches during the Boston Regional to confirm this "on the ground". Watching recorded matches may introduce issues with different frame rates due to re-encoding, but it sounds persistent.
| FMS Light 2010? | alectronic | General Forum | 1 | 04-02-2010 09:28 |
| Finding FMS Lite | Jon236 | Off-Season Events | 5 | 29-09-2009 13:44 |
| [FTC]: FMS | saaby | FIRST Tech Challenge | 4 | 02-02-2009 17:12 |
| [FTC]: Field Timer (similer but not the FMS) | team2845 | FIRST Tech Challenge | 0 | 19-12-2008 17:52 |
| Small bug | Jay Lundy | CD Forum Support | 1 | 18-06-2001 17:03 |
