Go to Post I can see the 2013 Kickoff broadcast now: "Hello Teams. Welcome back. Gracious Professionalism. Here's some homework. Here's the animation. Here's what the actual field looks like. RTFM. Peace." - sanddrag [more]
Unread 19-03-2010, 20:40
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Death of our cRIO, and some suggestions for NI
Today at the Detroit district event our cRIO suffered a slow decline to its ultimate death. Actually, I don't think it's completely dead, but at least the power connector doesn't work leaving it dead for all intents and purposes. The slow decline (intermittent problems) caused us to sit stationary for 20-30 seconds in a match or two, and the death caused us to sit still for the entire match after our first kick (the shock inflicted the final blow).
I've been very supportive of NI and the new control system, but I have some constructive criticism here. I don't want this to become a "piling on" thread, but I have one suggestion that would have saved us from missing a match.
Once we decided we needed to swap the cRIO, we had to get a loaner, which means we had to re-image the cRIO to set it up with our team number. Issues with the imaging process cost us about 40 minutes and we finally decided that the loaner cRIO wasn't working, so we had to go to a SECOND loaner. All of this wasted time caused us to miss a match altogether. With some simple changes, we could have easily saved 30 minutes and we wouldn't have missed the match.
Sorry for the long backgroud, here's the rub:
The cRIO Imaging Tool needs a status bar
if that wasn't clear,
THE CRIO IMAGING TOOL NEEDS A STATUS BAR
During the re-imaging process, the tool got to the "Formatting the cRIO" part, and sat there saying that for a long time. Without some sort of status bar, we had no idea if the process was still working, it was hung up, the cRIO crashed, etc. If we could see a) a status bar that stopped moving, or b) some type of "still working" feedback like what you get when a web page is loading, we would have known that the process was stuck.
Considering how long it takes to reformat the cRIO (and how much time pressure we were under), we didn't want to cancel the process and start over, especially if it was this close to being done. But without a status bar, we had NO IDEA.
We finally wound up canceling the operation, trying the safe mode thing, and that hung up as well (at least we assume it hung up, but we had no way of telling without a status bar (does anyone see the common theme here)).
Anyway, after 40 minutes of frustration, we finally decided that it was time to get ANOTHER cRIO. That one imaged without issue.
Once again, here's my beef: if we had a status bar, we probably would've noticed it frozen within the first 2 minutes. We could've tried it again, noticed it frozen, then got another cRIO. That would've saved us at least 30 minutes, and we wouldn't have missed a match.
I know that the tone may seem a little angry, but it really isn't. I'm actually keeping fairly light-hearted about the whole deal, all things considered. So, if you came away thinking I'm furious, re-read this post with a sarcastic yet light-hearted mindset.
Anyway: Status bar - PLEASE.
Unread 19-03-2010, 20:58
Re: Death of our cRIO, and some suggestions for NI
Good idea. I've made sure the right people have seen your request.
The Lucas's Avatar
CaMOElot, it is a silly place
I realise if the power connector is dead it is unusable and you actually needed a new one. However, I have to ask:
Did you try puting the cRIO in Safe Mode and reimaging it?
I have seen the same problems and I was always able to fix the cRIO by putting it in Safe Mode (flip DIP switch), restarting and imaging (3 different cRIOs, 2 ours, 1 another team at MD). Of course after you format it in safe mode you have to turn safe mode off and format it again. This whole long process is made worse because you are staring at a screen with no status bar and everyone keeps asking "when is it going to be done?" and you keep telling them you have no clue, but it will probably take a long time However, once this excruciatingly painful process is done the cRIO usually works as good as it ever had. Unfortunately, then I have to tell everyone I need another minute to reinstall the CAN plugin and download the code
Robot Inspector
Unread 19-03-2010, 21:02
I have seen the same problems and I was always able to fix the cRIO by putting it in Safe Mode (flip DIP switch), restarting and imaging (3 different cRIOs, 2 ours, 1 another team at MD). Of course after you format it in safe mode you have to turn safe mode off and format it again. Of course this whole long process is made worse because you are staring at a screen with no status bar and everyone keeps asking "when is it going to be done?" and you keep telling them you have no clue, but it will probably take a long time However, once this excruciatingly painful process is done the cRIO usually works as good as it ever had. Unfortunately, then I have to tell everyone I need another minute to reinstall the CAN plugin and download the code
Our cRIO was dead via the power connector (no lights whatsoever on the cRIO).
For the first replacement cRIO, we did do the safe-mode thing (I've helped other teams do it at Kettering) - no dice.
Unread 19-03-2010, 22:17
DjMaddius's Avatar
DjMaddius DjMaddius is offline
AKA: Matt Smith
FRC #2620 (Southgate Titans)
DjMaddius is an unknown quantity at this point
Im extremely glad you guys got another cRIO before match 46. You guys basically boosted up back into the top 10. Thanks
Unread 19-03-2010, 23:41
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Without hijacking the thread, since this is along the same lines, can you ask the same people to add a "pause" feature to the otherwise-great NetConsole?
The old IFILoader terminal had a nice pause feature that was useful during debug.
Unread 22-03-2010, 07:49
That sounds familiar. A team at the Boilermaker Regional had pretty much the same symptoms. After they replaced their cRIO, I took a close look at the "bad" one with one of their students. There was a small crumb of aluminum in one of the unused module connectors, underneath the plastic cap. I don't know if they got around to testing it again, but I suspect it now will work fine.
Suggestion: look for debris that might be shorting a power connection.
Unread 22-03-2010, 08:13
I'll call the school and have them look into that. Thanks.
Unread 22-03-2010, 08:31
O-H
Sounds like yet another reason to mount the cRIO vertically, in a "panel mount" orientation. This minimizes the risk of the cRIO chassis turning into a robot debris wastebasket.
Unread 22-03-2010, 09:34
Sure. I have access to the source, I'll try to make the change this week (schedule providing).
Unread 22-03-2010, 14:33
As it turns out, that wasn't the issue. I know we always had our empty connectors covered, but I wasn't sure if any of them came uncovered. The people at the school said they were still covered and everything was checked to be clean when the cRIO was pulled out of the robot.
Unread 22-03-2010, 15:32
Bob Bonczyk's Avatar
Bob Bonczyk Bob Bonczyk is offline
FRC #0107 (107 Team R.O.B.O.T.I.C.S.)
Rookie Year: 1995
Bob Bonczyk is a name known to allBob Bonczyk is a name known to allBob Bonczyk is a name known to allBob Bonczyk is a name known to allBob Bonczyk is a name known to allBob Bonczyk is a name known to all
At West Michigan there were four teams that had crios go out that I knew about. We fixed two of the four crios by replacing the internal fuse.
"Happiness lies in the joy of achievement and the thrill of creative effort." Franklin D. Roosevelt
Unread 22-03-2010, 15:37
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Bob,
Did you really mean to say that you opened the cRIOs and replaced the fuses or did you open up the PD (aka Power Distribution) and replace devices within it?
Neither resolution is obviously preferable but there is a big difference.
Russ
Unread 24-03-2010, 11:51
Rookie Year: 1995
We opened the crios that ere out of warranty.
Unread 24-03-2010, 16:05
It is my understanding that they don't go out of warranty... What made you believe this was the case?
For some reason our motors are "breaking" and not going forward. Why? Bensky Programming 3 25-01-2008 13:39
Need some suggestions hao1300 Website Design/Showcase 6 31-07-2005 11:32
Suggestions for our web DCA Fan Website Design/Showcase 7 19-04-2003 18:24
