Go to Post I mean who does want to write their code like this... [CODE] CANHAZ.VICTOR; GIMME.VICTOR; VROOMVROOM.VICTOR(1); KTHNXBAI; [CODE] - JohnFogarty [more]
Unread 24-03-2010, 21:35
mobilegamer999 mobilegamer999 is offline
FRC #3357 (Comets)
mobilegamer999 is a jewel in the roughmobilegamer999 is a jewel in the roughmobilegamer999 is a jewel in the rough
Analog Pressure Gauge
Hello all, i am wondering if there is anywhere that i can get a fairly cheap analog pressure meter for the pneumatics system thats rated for 120 psi. I'm looking at having a way to read in the PSI in the program so it knows when it has enough pressure to kick. Ive been looking around the internet for a meter but they were either very high ranges (1-10,000) or very high accuracy (+- .0001 psi) and they cost like about $500.
Unread 24-03-2010, 21:49
Re: Analog Pressure Gauge
While still not cheap, sensata makes pressure sensors in the $100-$200 range. A similar one was included in the kit in 2004.
Unread 24-03-2010, 21:54
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Perhaps you can cannibalize it from a digital tire pressure gauge like this one. Just have to make sure its rated for 120psi
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 24-03-2010, 22:16
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
We used this one from DigiKey for $115 and it worked perfectly.
Unread 24-03-2010, 22:25
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We bought a pressure switch similar to the Nason switch in the kit, but with a lower "on" pressure, in 2008.
It won't tell you what the pressure is, but it will tell you if it's above the pressure of the switch.
McMaster Carr 3454K1
it's about $50 and you can specify the pressure.
how do i get a pressure gauge on my driver station instead of the gyro gauge 2544HCRC General Forum 3 23-02-2010 11:08
cost of pressure gauge Gary Dillard Pneumatics 0 16-02-2010 15:55
Pressure Gauge neoshaakti Pneumatics 1 25-01-2008 20:50
3rd pressure gauge? Maximus123 Pneumatics 1 07-02-2007 00:30
Rules about pressure gauge position Kamen64 Rules/Strategy 1 06-02-2007 19:15
