Go to Post I believe that FIRST in itself is a reward. - link871 [more]
Unread 25-03-2010, 00:17
krudeboy51's Avatar
krudeboy51 krudeboy51 is offline
Only Programmer
AKA: kory
FRC #0369 (369)
krudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of light
Send a message via AIM to krudeboy51
HELP PLEASE!!
hi, i am a new programmer on my team, Can anyone please tell me how to program a spike in c++
class:
public:
please, some one help!!
Unread 25-03-2010, 06:39
Golto's Avatar
Golto Golto is offline
AKA: Pat Plude
FRC #4572 (BArlow RobAutics)
Golto is a glorious beacon of lightGolto is a glorious beacon of lightGolto is a glorious beacon of lightGolto is a glorious beacon of lightGolto is a glorious beacon of light
Re: HELP!!
Define the spike as:
Relay *[variable here]
Initialize it as:
[variable name used above] = new Relay([Relay port it's plugged into on the DSC])
To use it, place where needed in your code like this:
[variable name]->Set(Relay::kForward)
-OR-
[variable name]->Set(Relay::kReverse)
-OR-
[variable name]->Set(Relay::kOff)
Unread 25-03-2010, 06:58
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: HELP!!
That is one way to do it. However, instead of declaring the Relay as a pointer (*) you can do it this way:
class Team1771Robot : public SimpleRobot {
RobotDrive driveTrain;
Joystick leftStick;
Joystick rightStick;
Shooter mainShooter;
Relay mySpike; //Declare your spike's name here
public:
	Team1771Robot(void):
 	driveTrain(LEFT_DRIVE_MOTOR_PORT, RIGHT_DRIVE_MOTOR_PORT),
	leftStick(LEFT_JOYSTICK_PORT),
	rightStick(RIGHT_JOYSTICK_PORT),
	mainShooter(SHOOTER_TENSION_PORT, SHOOTER_RELEASE_PORT),
             mySpike(MYSPIKE_PORT) //Put whatever slot the spike is.
Later on in your code, say, in the teleop, you can say
void OperatorControl()
while(isOperatorControl() && !isNotDisabled())
mySpike.Set(Relay::kOff); //Or forward, reverse, etc.
HELP!!!! we need help w/ compressors/pneumatics for teleop/autonomous in LABVIEW rokenboker NI LabVIEW 9 05-02-2010 17:10
Grab Frame - Help Help Help... nmihailidis Programming 2 04-03-2007 14:44
section 'InterruptVectorLow' type is non-overlay (was: HELP HELP HELP!!!!!) naor52 Programming 14 24-02-2007 01:19
Help: How do we get a teacher to help? (was: Help) ChaosAlchimey General Forum 13 21-01-2007 11:57
