Go to Post Mostly, however, I find that once the students start building a robotics project, they are too busy learning for me to teach. - dtengineering [more]
Unread 24-03-2010, 13:05
Zme Zme is offline
FRC #2619
Zme is on a distinguished road
command line input...
This is going to sound very very crazy but...
Is there a way for a text input to be taken into the robot from the DS and have it function like a command prompt of sorts, ie. we have a function called runmotorx that takes in a float so we type in runmotorx (float value) and it takes it in and executes it.
is something like this done with reasonable ease? hopefully with out 100's of if statements.
any ideas on how to do this?
Unread 24-03-2010, 15:40
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: command line input...
can it be done? yes
is it competition legal? most likely not
what would you need to do? lots
you would need to manage a socket connection, and listen for incoming data, once you heard the enter key, the proceed to a switch or if's which would get the first word, and call that function (optional), then process the rest of the input and do the function. why you would want this (aside from the coolness factor) is beyond me. unless you have a expert typist, i would not want to control a robot like this
this would definitely go in the summer project bin
Watchdog.Kill();
Unread 24-03-2010, 15:50
Zme Zme is offline
FRC #2619
i was more thinking as a debugging tool, think about it, instead of having to remap buttons to do certain functions especially for debugging you could just type in the command and away you go,
the hangup on me just going off and playing is i have no idea how to evaluate a text input without large amounts of if statements which i was hoping to avoid,
as for it being legal, if it was in the bandwidth for the dashboard wouldn't it fall in under the rule of being able to modify that code?
Unread 24-03-2010, 17:59
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
If it is for debugging, why do you need to enter it through the DS? I was planning to develop an interactive debugger through the debug console (i.e. give you a prompt so that you can enter some debugger commands to the robot to do things such as turning on tracing, changing PID constants without recompiling code, dump some important states on demand etc.). But I do not have time to do it this season. So may be a summer project... The only difficult part was to figure out how I can prevent the input go into the cRIO kernel debugger instead of my interactive debugger.
Unread 24-03-2010, 18:54
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
You could probably bypass the whole socket/command-line thing and have it periodically check the robot's local storage for a text file with a certain name.
Something like
while(true)
  // not shown: feeding watchdog or disabling it
  ifstream in;
  in.open("commands.txt");
  while(!in.fail() && !in.eof) // if we managed to open the file, and it has contents...
    int motorChannel;
    float motorPower;
    in>>motorChannel; // loads the channel we want to output on
    in>>motorPower; // loads how fast we want to run the output
    PWM pwm(motorChannel); // declares an interface to the channel
    pwm.Set(motorPower); // outputs the desired amount
    Wait(5.0);  // lets it run for awhile
    pwm.Set(0.0); // turns the motor off
  Wait(5.0); // don't constantly check the storage device.
You could then just FTP the commands.txt file to your robot whenever you wanted to run something.
The commands.txt file would just look like <motor channel> <motor power>. i.e.
4 0.5
4 -0.5
3 1.0
3 0.5
3 0.25
3 0.0
Unread 25-03-2010, 10:21
Zme Zme is offline
FRC #2619
the reason for not using a command text file is that it requires a specified format, and order for the inputs, if any functions are added then the function that needs to read in the text file will also have to be changed, and it will always run everything in it, as for the input not having to be on the DS, no it doesn't have to be but i figured that since it already is connected to the robot, it couldn't hurt to use it over another laptop, but in the long run i don't think it matters
Unread 25-03-2010, 10:39
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
vxWorks has a facility that allows the execution of commands from a text file as if it were a script.
What you can do with it is execute the same commands you would execute at the vxWorks shell prompt -- no more.
The text file(s) need to be in a file system -- FTP them.
It is not junior programmer stuff though and the interpreter doesn't know how to parse floating point arguments :-(.
Search through Workbench Help for "shell commands" and "ptyDevCreate'.
Unless you are very good *and* willing to work very hard, you probably won't be able to utilize it this year.
Consider making it an off season project.
I can help you with it -- I have example C code I can share.
If you want it, send me an email gvarndell@hotmail.com
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
Last edited by gvarndell : 25-03-2010 at 11:26. Reason: clarify, offer real help...
Unread 25-03-2010, 11:54
Zme Zme is offline
FRC #2619
willing to work hard check
very good, not so much,
Thanks for the help
Unread 25-03-2010, 22:10
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
I've got a web server running on our robot, allows us to change values and stuff like that. No text input at the moment, but doesn't mean you can't extend it to allow it. *Extremely* useful for debugging.
http://code.google.com/p/webdma/
Unread 25-03-2010, 23:26
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
Surely you are aware of the NetConsole application... it is a C interpreter that allows you to call C entry-points directly. It is not competition legal.
You can also use the dashboard video tcp connection, but that will require you defining your own set of commands (your many if statements). This is competition legal, but more work.
Unread 25-03-2010, 23:39
gvarndell's Avatar
Software Engineer
FRC #1629 (GaCo)
Team Role: Parent
I get so little time on a robot.
Does it parse floating point arguments?
It's just a shell with re-wired stdin and stdout, right?
Unread 26-03-2010, 00:50
mikets's Avatar
Software Engineer
Ahh, does it mean I could have a Debugger object defined in the Robot code with the method "PromptDebuggerCommand()" that will interpret my own debugger commands. So I can invoke the method in the NetConsole or debugger console? How? It could be very handy when debugging code.
Dashboard command line? Phoenix.14 Programming 3 13-03-2010 10:13
command listfor c??? jfrank Programming 12 22-01-2008 20:16
assembly command tseres Programming 3 18-01-2008 08:13
2.5 is alive !!!! (input ! .. more input ! ) Lloyd Burns Programming 2 14-01-2003 19:15
New Line Input Parsing Trashed20 Website Design/Showcase 6 30-09-2002 10:46
