Go to Post I was cheering like mad during the last match on Einstein - I think the rest of my team thought I was crazy...or crazier than they thought I was before! - Sean Schuff [more]
Unread 18-03-2010, 01:22
Geek 2.0 Geek 2.0 is offline
FRC #0107
Geek 2.0 will become famous soon enough
Virtual Console Backspace Character?
This isn't all that important, but it's a curious thing for me... Is there a backspace command we can send to the Virtual Console to backspace the last character sent? I tried "\b" but it didn't work...
Again, it's not important, but ever since the build season ended, programming (outside of competitions, that is) has been rather dull, so I'm adding "fun" code. (and yes, I realize the danger of this)
Unread 18-03-2010, 18:38
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
Re: Virtual Console Backspace Character?
The standard linux escape list can be shown here:
List of escaped characters
Yes, im referencing an AWK manual, but it has the list I use all the time.
The closest character to it is a space because there is to backspace escaped sequence. It is interpreted by the scanf, raw_input, readline, or whatever function your language of choice uses to get input from the user.
A word of advice: fun code blows up speed controllers
Unread 24-03-2010, 21:34
LukeS LukeS is offline
4272 mentor, 1024 alumnus
AKA: Luke Shumaker
FRC #4272
LukeS is an unknown quantity at this point
'\b' for backspace should work, however, it will not be able to delete a newline, so you may have problems with println appending newlines. Though, I haven't tried this on the cRIO or anything.
And when messing around be careful, but hey anything worth doing has some risk.
Unread 25-03-2010, 12:03
FRC #0107
Yeah, I tried '\b' but it didn't work. Really, all I was trying to make was a "spinning" line, with |, \, -, and / looping so that it created the illusion that it was spinning. Now this might seem pointless, but there actually was a reason... I was getting sick of the disabled loop spitting out endless lines of code, yet I wanted a way to tell if it was still reading from the cRIO. Not important though. I might look at it more in my spare time (as if I have any now).
Unread 25-03-2010, 12:23
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Are you talking about the driver station console? If so it is treated analogous to the LCD screen of last year which means you are essentially "painting" characters on the screen. To delete characters you have to output a space at that position.
Example:
"here is some text"
to just say 'here' you would have to output
"here "
to erase the entire line:
So for your thing instead of backspace:
etc.....
Also keep in mind that an update signal must be sent each time the LCD text is set or it won't appear animated.
If I am totally misunderstanding what you are trying to do...apologies!
You can try a unicode backspace too: \u0008
I don't need a signature.
Unread 25-03-2010, 17:00
AKA: Luke Shumaker
FRC #4272
I think he's talking about the `System.out' (stdout in non-Java lingo) stream--In Netbeans, and you click run, the output box will start streaming stdout from the cRIO once it is done compiling.
Although, We have found that unless you need more than 21 columns per line (the physical size of last year's LCD), using the text area on the driver station is better for just about everything. If certain aspects of it are a pain, borrow our LCD.java from our code.
Hey you don't need to explain the importance of a baton to me.
Unread 26-03-2010, 00:12
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
It's a console, right? So why not try the backspace? Have you tried ctrl-h (0x08)?
-Joe
Unread 28-03-2010, 19:00
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
-Joe
If what Joe said doesn't work, you could try \010, a backup for \b.
Unread 29-03-2010, 01:56
jhersh jhersh is offline
AKA: Joe Hershberger
Last I checked, 010 == 0x08 == 8. Welcome to the world of octal... aka base-8 numbers.
Animated Character Help 16MentalTempest 3D Animation and Competition 13 29-03-2009 15:53
Line Continuation Character in MPLAB? brianafischer Programming 4 27-01-2007 19:26
Name That Character! Amber H. Chit-Chat 18 17-01-2003 15:44
character studio archiver 2001 2 23-06-2002 23:41
ss of team 30's main character =) RobDeCotiis 3D Animation and Competition 0 18-02-2002 08:19
