Go to Post I'm nervous for those awesome rookie teams that you may not know about much but that just come and do awesome with some fantastic strategy...Rookies rock. - Eugenia Gabrielov [more]
Unread 25-03-2010, 10:43
team3329 team3329 is offline
None #3329
team3329 is an unknown quantity at this point
Compressor and Pneumatics help for 3329
We are using Labview. We are nubes at this so lots of help would be usefull. We are having trouble with our compressor and pnuematics system - for some reason our compressor was working but we ran into trouble. We put our Compressor Open.vi >> Compressor Start.vi in the periodic tasks inthe 100ms loop. It worked for a while until We programed our solenoids in the teleop code (by setting the soleoids with the joystick buttons - we have a duel solenoid valve) and then we got error codes: -44027 and -44046. It says the DIO module has already been allocated but our set up for the compressor is correct. We're really confused!!!! Please somebody help!!
-- thanks --
Unread 25-03-2010, 10:46
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Compressor and Pneumatics help for 3329
Big problem - Put the Compressor Open in Begin. It has already allocated the compressor in a previous loop, so you can't open it more than once. You can put a Start in Begin then set a refnum and pick it up in PeriodicTasks to Start.
Kettering Motorsports
Unread 25-03-2010, 10:50
None #3329
HEy thanks! We tried that already but the watchdog started misbehaving. And thats where we are lost. It doesn't show that message anymore but the compressor still isn't starting
Unread 25-03-2010, 11:10
None #3329
Hey again! I tried what you said again and its giving us error code -44027
I put the Get refnum.vi >> Compressor start.vi in the 100ms periodic tasks loop. I'm still not sure on what to do
Also I just deleted all watchdog references so i wouldn't get any trouble with it
ps: thanks for responding so quickly
Unread 25-03-2010, 11:20
apalrd's Avatar
More Torque!
VRC #3333
In Begin.VI:
Open Compressor (configure the DIO Port, DIO Slot, Comp Slot, and Comp Relay) -> Compressor Start -> Compressor Set Refnum (name it "compressor" or something like that)
In Periodictasks OR Teleop:
Compressor Get Refnum (same name as before) -> Compressor Start -> Compressor Enabled State -> Indicator of Compressor Enabled State and Compressor State (those help with debugging - make sure the terminal for the indicators is in the loop with the Enabled State.
Run Robot Main.vi by pressing the play button. When it is done downloading and you have Teleop Disabled on the Classmate (with stop button, comm, and code), open Periodic Task.vi and look at the front panel. Compressor Enabled State should always be TRUE, and Compressor State should show what the compressor is doing. Then, enable it. The compressor should turn on.
Whatever you do, do NOT open the compressor more than once. You can use Start more than once, but NOT open. That will throw that DIO Cache error.
Do you have a Watchdog Feed in Teleop? Another thing I recommend - Call Teleop.vi from Disabled.vi. Then, you can see what the code is trying to do without letting it do stuff. Once the code is running from Robot Main (Teleop Disabled on the Classmate) you can probe wires and see what is happening. Be warned - Probing a wire before Robot Code is green will almost certainly cause LabVIEW to crash. Make sure Robot Code is green before probing. When you are done with the probing and indicators, you can do a full Build and Deploy. You must do a Build and Deploy to save the code permanently, so it is required at competition. Generally. I do a full deploy every time I leave or am done debugging.
One more reason for Watchdog errors: Do you have any WAIT's in Teleop, for something like kicker timing? That is a big no-no. You can run your kicker timing loop asynchronously (e.g. Periodictasks or something of the like) and communicate via global variables if you would like.
Unread 25-03-2010, 12:13
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
While you can call the Compressor Start VI more than once it really isn't necessary unless you called Compressor Stop for some reason.
Compressor Start launches a separate thread to handle the compressor which will run straight through Autonomous and Teleop just fine.
Unread 25-03-2010, 14:11
None #3329
Thanks ALOT!!!!!!!!!!!!!!! I'll give it a go and see if it works... Thanks !!!!!!!!!!!
Unread 25-03-2010, 14:32
None #3329
Ok. I tried it and there is now a comm error with the camera (-44003)
Should I delete the Camera script all together (if another option is possible that would be splendid)
Thnx
Buttons and Pneumatics Help huskyrobotics NI LabVIEW 17 15-02-2011 15:56
Solenoid Wiring and Compressor Help BurtGummer Electrical 16 17-02-2010 14:25
HELP!!!! we need help w/ compressors/pneumatics for teleop/autonomous in LABVIEW rokenboker NI LabVIEW 9 05-02-2010 17:10
help with Compressor and labview Team2883 General Forum 4 28-01-2009 22:18
AMPs for RC and Compressor beemgruem Electrical 9 10-01-2008 10:08
