Go to Post Don't underestimate the ability of a highly skilled technician with simple tools (and don't overestimate the ability of an unskilled fool with exotic tools!). - dlavery [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 24-03-2010, 20:36
Generator of Entropy
FRC #2973 (The Mad Rockers)
Re: A mentor perspective on what happened in FIRST Israel
Gary, each FRC field comes equipped with a selection of low-cost field elements and a piece of practice carpet. At least, for the fields here in the U.S., if there's space, those are pulled out and setup, unless a team brings one. The official contents of the practice field this year: 1 goal (with target, and chains that doubled as spares for the official field), 1 tower with platform, and 1 bump section, plus carpet. Not sure if the bump and ramp had carpet on them.
Thanks for the clarification Eric; that is certainly different than it used to be.
When you say "low-cost field elements", are you referring to the low cost design drawings on the FIRST website under the "Arena" section? Because this year, as I stated, the vertical posts in the low cost design were 4 x 4's, not 1.5 diameter tubing.
Unread 24-03-2010, 22:57
Exactly, Gary. The sort of thing a team would build to practice with.
Unread 25-03-2010, 11:51
Nadav Zingerman Nadav Zingerman is offline
FRC #2230
Nadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to behold
Originally Posted by Jon236 View Post
Several allegations have been made that the field in Israel was not to FIRST standards. That was not the case.
From "The Arena" Section 6.1
"The competition ARENAS are modular constructions that are assembled, used, disassembled, and shipped many times during the competition season. They may undergo a significant amount of wear and tear. The ARENA is designed to withstand rigorous play and frequent shipping, and every effort is made to ensure that the ARENAS are as identical from event to event as possible. However, as the ARENAS are assembled in different venues by different event staff, some small variations do occur. Fit and tolerance on large assemblies (e.g. the TOWER) are ensured only to within ¼ inch. Overall gross dimensions of the entire field may vary up to 4 inches. Successful teams will design ROBOTS that are insensitive to these variations."
The field in Israel was built with metric components to the specified tolerances. Our Head Referee, Stuart Bloom, measured the contested field elements and declared that they met 6.1 requirements.
I didn't measure the field elements myself, but I recall Leav (Sorta FTA) going through each team's pit and telling them the tunnel was significantly smaller than it should be.
Unread 25-03-2010, 12:57
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
The tunnel was actually not a problem, lower than the nominal* dimension but within tolerances.
Since we were allowed to measure the field, I wanted to make sure all teams knew the measured dimension so that my team would not have any advantage over teams that were not there at the time.
Also I had no official position this year I just lent a hand where it was needed when my team didn't need me.
-Leav
*nominal - number specified on drawing, actual dimensions will vary between two dimensions specified by the tolrerances.
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 25-03-2010, 18:07
yaron yaron is offline
Founder of 2214 & FRC Senior Mentor
FRC #1574 (MisCar)
yaron will become famous soon enough
1.5 tube is 1.5 tube, a tolerance for a diameter is not 4mm maybe 0.2mm. It is very reasonable for a team to design a lift system based on this dimension.
Another thing is the visible difference between the blue bumps and the red bumps. If it is so different than it is not engineering, and I thought one of the purpose of FIRST is to celebrate science and technology. You can not celebrate science and technology and forget about engineering. You invest hours volunteering and mentoring students in more then one team and assisting many others teams in order to eventually participate in a celebration of science and technology. The Israel regional, and I am maybe the most sad person in Israel to admit it, was far from a celebration of engineering, it did not serve as inspiration to many teams. Having said that and all what I mentioned in my previous post - nothing, and I repeat nothing is directed to the field people who were brought to an unbelievable situation by wrong decisions for the second year.
As a volenteer who spent three months with 3-4 hours sleeping each night being away for the whole night several times I am the last to show any disrispectfull to any volunteer in FIRST, and if someone took my "complains" as personal, this was not my intentions. I still want Israel to be the best regional in the world. Else, why would I mentor my student to assist so many teams in Israel. The general manger called me and the other mentor of MisCar the worst mentors in Israel because we push student to follow the system approach thinking model engineer follows. For me the FRC competition is very important, not because it is so important to MisCar to win, but because the competition is the only way to examine our process, to show students that inspectors, judges, teachers, engineers and other student appreciate thier achievements. If a well designed, well written code was able to be tested only for one game and only for 1 min and 50 seconds because of communication problems (the lift system was cancelled because the diameter was so out of the range, it was too danger even to try it), then something is wrong. No matter what best IDF or any other expert in the whole galaxy will say - this is not the way to run an event of 52 teams with over 1000 HS pupils and more then 100 mentors. You can not expose students to such a disaster. Too many pupils were crying, our captain was even brought to a first aid assistance because of what FIRST Israel general manager forced him to do!!!
And you know what, if all this was happening only to one team then I would say, sure they need to check themselves first, but it happened to many other teams.
Having expressed my self so long, I must also refer to another issue. You know me since 2006 we have been meeting In Israel and in Atlanta every year. Mentors in MisCar are devoted to FIRST goals and spirits - to all of them, and when FIRST-ISRAEL general manger blames us as people who are nor educating our student to the same values as we believe is .... I can't even find the word (and not because of the lack of English) to express my feeling on this.
And regarding your post about the FRC community in Israel - For all the US readers, I repeat again, Israel could be the best regional in the world because of the teams in it - only the management should be replaced. And I am not speaking on ALISHA who you know I respect and care for.
Unread 25-03-2010, 18:20
45Auto's Avatar
45Auto 45Auto is offline
FRC #2992
45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future
In the US, standard steel tube diameter tolerance for .500" to 1.700" steel tube is plus .005, minus .000. That works out to a metric tolerance of plus .127mm.
I can see where it would be very aggravating if the field wasn't even built correctly on top of all the radio problems ......
Unread 25-03-2010, 18:41
FRC #1574 (MisCar)
Originally Posted by RandomStyuff View Post
I hope this post brings new information to light and explains part of what happened. I would actually take the opposite stance and praise FIRST Israel for doing everything within their powers to get things working, even when it cost them more than they could usually afford. )
Dear RandomStyuff
It is pretty annoying that I do not know your name (Yaron is my real name ).
Your post really brought new issues to consider. I want to assure you that I respect the hard work and the extremely long hours you were exposed to failures in engineering that you are not responsible for. I (and everyone from MisCar and from any other team who know how much work need to be done in order to organize such an event) appreciate very much every single step you and others have taken to assist in solving problems. There is an idiom: a smart move is not to enter a situation that a clever move can fix - this is what FIRST ISRAEL should have done. Almost all of the details you mentioned are known from 2009, nothing have been changed, on the contrary probably got worst with communication networking in Nokia. Israel is known for best HiTech - no reasons can justify Israel regional to be less quality regional than NH!!!
I hope that you accept this and understand that not even one word of my long posts are referring personally to anybody. I want to improve FIRST ISRAEL at least as you, but unfortunately I can not join you in praising FIRST Israel for the 2010 regional.
My feelings are heart not only because of all the mentors from many teams who are desperate but also for students who said never again - there are other excellent robotic programs with lesser disappointment from the final celebration of science and technology - the competition - mentors and students might consider these. I personally will not do so, and continue in assisting FRC teams in order to improve the FRC community and hope FIRST Israel regional will be a better celebration of good engineering.
Unread 25-03-2010, 18:50
FRC #1574 (MisCar)
In Israel you could find at least 8 arenas, teams constructed according to the full details of FIRST drawings. The tower is so important in the 2010 game to demonstrate capabilities of creative solution to lift the robots. If only we knew that in the PIT there will be such a poor arena could spread it to the team I am sure many would volunteer to bring an official arena to the pit. Actually, last year, one my suggestions (as FRC senior mentor) to lower the cost of the Israel regional was to have different teams be responsible for the different parts of the official arena, but make sure in advance that all parts are exactly like the official drawings. There are many teams who construct official arena anyway.
Unread 26-03-2010, 05:39
RandomStyuff RandomStyuff is offline
FRC #2212 (Spikes)
RandomStyuff is a jewel in the roughRandomStyuff is a jewel in the roughRandomStyuff is a jewel in the roughRandomStyuff is a jewel in the rough
Well, first of all, my name is Niv, I'm the programming lead of #2212 (The Spikes from Aleh Madaim Lod), so now you know my name.
I apologize about my rant earlier, I know that it wasn't a personal attack of sorts against FIRST Israel or anyone in particular. At that moment I saw it as somewhat of an attack and therefore had to respond.
I think FIRST Israel did most of what is in it's powers to get things working. That's what I said throughout my post earlier. I did not imply in any way that the Israeli Regional was done well! I see the Israeli Regional as a failure in many areas, including the technical areas I helped fix. I do not think that blaming anyone is the correct thing to do, it will not solve anything and we will not redo the regional this year. I do think that finding the problems so that we can attempt to fix them is the correct thing to do, and if what you tried to do was give constructive criticism to help for next year I apologize for the way I reacted.
The problem is that statements such as "the management should be replaced" does not constitute constructive criticism in my opinion, and should not be thrown around without having seen their side. I can only give you the part that I saw, during the night. Yarit and Asaf Agmon stayed with us until nearly morning, and Alysha stayed for pretty much the whole night. They really did everything within their powers to fix what they could, and gave us all the resources we asked for. So who do you wish to replace if everyone was doing their job to the fullest? Maybe the addition of a technical manager to the management with more experience in networking is in order. Maybe more coordination with the teams on building the field is in order. But the management of FIRST Israel did nothing less than everything that they could.
I agree that the Israeli Regional can be much more than it is. For the past two years, ever since we have moved from the old radio based system to a fully IP based, networked system, nothing but problems have plagued us. Some of it is related to us having to use equipment that is different from that of FRC regionals in the USA (due to military usage and decisions of our version of the FCC, the frequencies used in the USA and some of the channels used are illegal here in Israel, and therefore some equipment that uses these settings is also illegal and not permitted into the country!). In my team, the programmers and some of our builders (most of our team is majoring in Computer Science, including our builders, which is pretty awesome because they actually understand what is possible in code) have started talking about possible solutions for next year, because even with this year's "fixed state" there were problems.
Communication:
The communications problems were mainly due to networking, not wireless, but they stem from the wireless in the equipment other regionals use not being legal in Israel. One possibility is asking for the FMS equipment to be sent earlier, and then tested with 6 demo-bots, and fixed before the competition. Another possibility is contracting the networking to an external company with expertise in the field. From the awe of the networking expert from the IDF that I worked with, he was amazed by the robots. Although it is not the goal of FIRST to bring adult technologists into FIRST but make FIRSTers into adult technologists, I believe this time it might have proved to be a two-way street and would certainly not be surprised to see him next year at the regional. With enough time and now greater understanding of the FMS, I'm sure that he could help iron out all the little bugs that made even the eliminations un-optimal.
As for the bad code issue;
I am not sure if the issue stems from bad code locking up the field, but just in case it does: Most of the teams have programmers which barely know their code or what they are doing. Last year I went to two teams, both rookies, and taught them programming from the basics of what is an IF and a WHILE to moving the code onto their robots. This year, one of my programmers went and did the same to an additional rookie. I'm sure other teams exist with programming experience that stems from what they taught themselves or what other teams taught them in 4 hours, or even only from what they learned during the 2 hour lectures at Tel-Nof (I'm pretty sure that identical lectures existed also in different places, but Tel-Nof is closest to me.
These quick courses do not teach proper programming, and many teams stick with what they see makes the robots move, even if it's not well done. While I doubt that these coding errors are the cause of the problem, cancelling out that possibility is very important, and better programmers overall would raise the level of FIRST in Israel. An idea that came up in my team(and yes, we do sit around a table and just talk about ideas related to FIRST, we are a bunch of people with no life ) is to host a summer programming week.
I'm sorry for my posts being this long...
Because using your robot's cannon to shoot at your nation's Minister of Education is worth all the 6 weeks of no sleep!
Unread 26-03-2010, 07:13
FRC #1574 (MisCar)
Niv, Thanks for your warm words, now we both know that we have one goal in common, improving FRC comunnity in Israel.
My main job is a director of the Israeli natonal center for technology teacher. Although I can not run workshops for students I can organize workshops for teachers (or mentors). We have just finished one in Tel Aviv. We will have another one this July, all details (in Hebrew), in the center website: moretech.technin.ac.il
I think we luck mentors with deep understanding of engineering education especially in the field of progrmming, networks, communications and sensors.
FRC is for students being mentored by adults, let us work in both direction, improving the mentoring process will improve student learning, improving student learning will teach mentors new and facinating domains, my best teachers in my 22 years of field practice were my students.
Leomi Robotic center at the technion has the resources to orgnize workshops for students and I began working with the director to organize joint workshops.
In the meantime, MisCar organized in the north severl times in the last four years intensive seminars open for all teams in all aspects of FRC. In the last workshop seven teams came from all part of Israel. We will continue to assist any team.
Take care,
Yaron
Unread 26-03-2010, 11:17
FRC #2212 (Spikes)
I'm not sure that going through the mentors is the correct way here. I know FIRST is partially about the students learning from the mentors, but I think that in every field where students can manage alone, it's even better. For example, in my team, we have 4 programmers who are all students, and a mentor which is half mechanical and half programming. In terms of mentoring us in the programming team he sits with the team and helps prioritize different goals (such as that it's more important to get our swerve drive system done than program our own event-based library) and goes over our code at the end to see that we have no errors. Now, maybe that's just our team, and I do realize that my school is not normal in that computer science is our expertise, but I really do believe that when possible, FIRST should be a student thing.
I think a better solution is rather than mentors teaching mentors which teach students having students teach students. I've already started getting the ball rolling on this with my school to try to organize this. I assume that if I do manage to get this up and running you will hear about it soon enough...
Unread 26-03-2010, 16:02
yarden.saa's Avatar
yarden.saa yarden.saa is offline
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
yarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond repute
FIRST Israel had many problems that not communicate to the field.
THE INSPECTORS
they were not following the rules at all
THE PIT PRACTICE FIELD
I didn't know that teams brought their field. If I knew it my team would have bring tower and bumps as the rules which looks good(the tower in the practice field was looking very bad)
THE PIT AREA
The light in the pit was weak. we could not see any thing in the robot circuits. the reception desk could not say any announcement to the teams becase the noise. the pits were not orgenized and there was a full mess.
THE STADIUM
To get to the pit you had to go by a kiosk becase the gates were not open.
THE FIELD
I agree that the field looks smaller. the field in the pre seasom was much bigger(the pre season field was by the rules of length and width).
the bumps if many teams robot tried to drive over the bump and fail it's okay, but they were not trying if the knew in their school that their robot can drive over the bump. the tower was okay(my team's robot has an hanging mechanisem and it works)
the tunnl was okay and you cannot blame it was not okay because I saw many robots that designed to drive in the tunnel by querter of a milimeter less then its height. it's not wise because the tunnel cannot be built ecsactly every time.
THE COMMUNICATION]
As I said before, the system had to be test at least 3 weeks before the competition with 6 robots in NOKIA Arena. everyone know what happened in 2009. everyone know that what is legal in US is not legal in Israel. everyone knows the BIG problem was becase something they don't know till now. the guesses of what the problem was are fine but truely; one team wrong code cannot affect 5 other robots. my guess I think should be test more seriously;
the place of the arena is bad. it's near to the "kerya" - "Israel pentagon", there are 150 wireless networks that you can to connect with the laptop in NOKIA Arena. the signal is not the signal in US. the routers place was not the most intelligent as our mentor who works in this section said. the routers place was wrong and how big the router is ("the biggest router in israel") it doesn't matter the need to provide communication to a little place of 54*18 foot(if i am not wrong).
THE EVENT COST
the teams should not pay 11500$ every year regulary. it's not realistic. the Arena is free (TEL AVIV muni. donate it).
The field router should be rent by a company in the US or to buy one after 2 years of event testing if the router is successful(eventhough I don't think the router had a problem). the field except to the electrical should be built in israel.
as a new member in this events(See you in the championship) it was painful. but I have to say some good words; I think FIRST spirit was the best thing that happened to Israel regional. it happened thank for the mentors, volunteers and the best students of ISRAEL.
pic: What on earth happened? (or what on the moon??) Kims Robot Extra Discussion 27 10-02-2009 21:59
What happened to the FIRST community I call my family? Arefin Bari General Forum 39 21-04-2007 14:49
So what happened at the FIRST forum Todd Derbyshire General Forum 57 05-08-2002 22:18
What happened at IRI? Jeff Rodriguez Off-Season Events 38 24-07-2002 18:39
What Happened to SOAP? Tom Schindler General Forum 3 14-06-2001 21:25
