Go to Post Dear Dave, I've been a good student this year. Can I have hint #2 for Christmas? ~Zach - Zach O [more]
Unread 11-03-2010, 23:26
Kyledoo Kyledoo is offline
FRC #2603
Kyledoo is an unknown quantity at this point
switching turning direction using arcade drive?
We have implemented a way to change the polarity of the motors by hitting a button(simply using the SetInvertedMotor), and in this way, we can select which end of our robot is the front. However, while in the reversed mode, pushing the stick to the left turns the robot to the right. I was exploring a way to basically invert the x axis of the joystick. any ideas on how to do this? oh and we have our first matches tomorrow, so i'm hoping to figure it out sooner rather than later!
We are using C++
Unread 11-03-2010, 23:32
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: switching turning direction using arcade drive?
if(inverted)
xOut = x * -1;
Couldn't be more simple than that.
Kettering Motorsports
Unread 11-03-2010, 23:35
You can use the ArcadeDrive method that takes raw values for the speed/turn inputs. This is the signature:
void RobotDrive::ArcadeDrive(float moveValue, float rotateValue, bool squaredInputs = true);
So instead of doing something like this
 myDrive.ArcadeDrive(myJoystick);
You could do something like
float orientation = 1;
if(goingBackwards)
   orientation = -1;
myDrive.ArcadeDrive(myJoystick.GetY() * orientation, myJoystick.GetX());
You shouldn't have to reverse the motors with that.
EDIT: You shouldn't have to reverse the X axis actually. Kind of counter intuitive, but thats the way it works out. A left hand turn is a left hand turn looking forward and backward. You just want to change your direction. (moveValue)
Unread 12-03-2010, 00:05
FRC #2603
Thanks for the great quick responses! I really can't believe i missed that now... but anyways, is anyone timing the release of pnumatics(we want to leave our kicker extended for a full second once we press the button). What makes most sense to me is to use a for loop, and possibly put this inside an if.
For example:
if(buttonpressed){
for(i = 0; i<10; i++){
// whole code
//feed watchdog
s1->Set(true);
Wait(.1);
any experiences with this? we basically have tomorrow morning to test all the code and make any necessary modifications so i'd just like to know what to expect. Also, would this concept work for restricting kicker movement after it retracts(so we don't get a penalty)?
Unread 12-03-2010, 02:26
You probably dont want to have any kind of nested loops in your main program loop, unless you are certain it will execute fast enough. A for loop will block the execution of the code after it, and will fire the watch dog, or worse, cause your bot to "freeze" its output values while the loop is executing.
Instead, you could use a Timer object.
class MyRobot : public IterativeRobot
   // Declare the timer
   Timer * kickTimer;
   // Then down in the constructor...
   MyRobot(void){
      kickTimer = new Timer();
   void TeleopPeriodic(void){
      if( somethingHappened ){
         kickTimer->Start();
         mySolenoid->Set(true);
      if( kickTimer->Get() >= 1.0){
         mySolenoid->Set(false);
         kickTimer->Stop();
         kickTimer->Reset();
Or you could just increment a counter every time you loop around
static unsigned int solenoidCounts = 0;
static bool kickerFired = false;
if(somethingHappened){
   solenoid->Set(true);
   kickerFired = true;
   solenoidCounts = 0;
if(kickerFired){
   solenoidCounts++;
   if(solenoidCounts > 1 * 40){ // 40Hz(ish)
      solenoid->Set(false);
      solenoidCounts = 0; // just to be safe
It's not the prettiest thing in the world, but it gets the job done and its pretty easy to understand/implement/change.
Unread 25-03-2010, 23:17
FRC #2603
   Timer * kickTimer;
   MyRobot(void){
         kickTimer->Start();
         kickTimer->Stop();
         kickTimer->Reset();
   kickerFired = true;
   solenoidCounts = 0;
if(kickerFired){
   solenoidCounts++;
Hey. I know it has been awhile since I actually asked this question, but we are now at our second regional(Buckeye) and it has been quite hectic. I just wanted to thank you for all the advice, I used that same format you suggested and we were even able to put in a penalty preventer so that the kicker will not fire more than once every 2 seconds.
Semi-Omni-Arcade Drive byteit101 Programming 20 24-01-2010 08:21
Normalizing motor speeds using Arcade Drive in Labview rsisk NI LabVIEW 9 28-08-2009 20:56
Programming Arcade Drive kyungjin C/C++ 4 06-04-2009 11:28
Arcade/Tank Drive Malfunction piedmont Programming 2 19-01-2009 17:37
Arcade Drive Anfony VEX 4 08-11-2006 19:46
