Go to Post Striving to build the "best robot" is a fine goal -- don't hate on it. - JVN [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
  #31   Spotlight this post!
Unread 27-03-2010, 07:55
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Re: AndyMark Plaction Wheels
Correct, (and I hope 1501 will also back this up ) when you rivet, you need to drill the hole out the same size as the rivet. Not too small or too large, if it's too small you will not be able to get the rivet in. If the hole is too large, the rivet will not be 100% efficient as the rivet could wobble in the hole. Now, with adding the rivets in a zig-zag pattern, that might be a little over kill. But it never hurts to add security for such an important component.
A 1/8" rivet will NOT fit into a 1/8" hole. You need to drill the hole using a #30 drill bit.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
  #32   Spotlight this post!
Unread 27-03-2010, 09:24
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Not sure what kind of drill you are using but I have been putting 1/8 rivets into 1/8 holes and 3/16 rivets into 3/16 holes for as long as pop rivets have been available.
Bruce
  #33   Spotlight this post!
Unread 27-03-2010, 10:49
Emily3204's Avatar
Emily3204 Emily3204 is offline
The Mary Louis Academy
AKA: Emily Santoro
FRC #3204 (TMLA Robotics)
Team Role: Driver
Emily3204 is a glorious beacon of lightEmily3204 is a glorious beacon of lightEmily3204 is a glorious beacon of lightEmily3204 is a glorious beacon of lightEmily3204 is a glorious beacon of lightEmily3204 is a glorious beacon of light
Send a message via AIM to Emily3204
our team tried to use the plaction wheels, and we also had the same problem! we ended up changing wheels though because our turning maneuverability was poor
Emily Santoro
TMLA Robotics 3204
The Mary Louis Academy; Jamaica Estates NY
  #34   Spotlight this post!
Unread 27-03-2010, 19:53
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
We are running a chain driven 4x 8" -wheeled tank setup with dual-CIMed AM supershifter gearboxes on each side. As we entered the semi-finals of the Midwest Regional, we were losing staples and had to super glue the tread ends of one wheel. Then later in the semifinal, after not paying enough attention as to why only one chain was getting progressively looser after each match, we ripped a sprocket off that wheel, shearing bolts and shattering the sprocket, plus breaking the chain at the master link. Even though we had all six screws, they were low grade screws and several were slightly short and did not fully engage the nylon inside the Nylock nuts.
Because we have the dual sprockets on out gearboxes, with one chain to each wheel, our two rear sprockets are spaced away from the side of the wheel to line up properly with the dual sprocket of the gearbox. These spacers were not done right, and allowed too much flexing of the screws which finally worked themselves loose. This was the cause of the chain loosening, and by not zeroing in on the cause the problem went to self destruct stage.
We have now replaced all our KOP sprockets with new 22-tooth ones that do not have the six radial slots in them. We have replaced all our chains with 100% riveted chain (no master link & 50% higher working tension)). We have 1/2" diameter precision nylon spacers between sprocket and wheels. Screw heads are allen socketed (not slotted) so they can be seriously tightened. We now use Locktite blue on the the Nylock threads too.
As for tread to wheel attachment, after roughing up the plastic surface with abrasive paper, we are gluing the Roughtop treads onto the plastic wheels with GOOP Shoe Goo urethane adhesive. We use large hose clamps to compress tread material against the wheel overnight. This produces an almost inseparable bond.
We also decided to have spare upgraded wheels with sprockets mounted ready to go in case of failure. Handling the torque output of this drive setup demands that all components be made with top notch materials.
-Dick Ledford
  #35   Spotlight this post!
Unread 28-03-2010, 08:48
jfc358 jfc358 is offline
FRC #0358
jfc358 is an unknown quantity at this point
Angry Re: AndyMark Plaction Wheels
Has anyone else had problems with cracking of this wheel? We lost an entire segment of the rim, spoke to spoke, on one wheel yesterday and had to splint cracks in another. This appears to be happening when going over bump. Cracks seem to form on outside of facing side of wheel first and then propagate through wheel. Since the robot never comes down off of the bump completely square to the floor, the outside of one rim takes more of the impact. This is what we think is causing wheel to crack. At least that is what appears to be happening.
  #36   Spotlight this post!
Unread 28-03-2010, 13:58
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Our 6" plaction wheels started to exhibit cracking in the spokes almost immediately after we started going over bumps at competition weight.
Mistakenly, I ignored the crack in our competition robot wheel, as it was only on one half of one spoke. In semifinal match 1 at the Seattle regional, the wheel shattered into three pieces, splitting at each of the three bolts we were using to attach the drive sprocket.
We were able to swap in a wheel after using our time out and run semifinal 2, though because it was our front wheel, we couldn't make it over the bumps. We ran chain again before the finals and were back in full working order.
As mentioned earlier in this thread, we'd now recommend that all teams use all 6 bolt holes on these wheels.
--Madison--
...down at the Ozdust!
  #37   Spotlight this post!
Unread 28-03-2010, 16:50
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
It seems like everyone is using the Andymark wheels with the standard 1" wide tread, but did anyone besides teams 3193 and 48 use PVC spacers to widen the 6"-diameter wheels to 2"? We had success with them using black nitrile treads from McMaster in our 8-wheel drive, but we too had issues with the tread coming off when we tried using staples like the original AM treads. Two 1/8" rivets (1/2" long) drilled into the PVC spacer worked great.
However, we found another issue: when mounting sprockets, you have to watch how hard you tighten the bolts on the hubs, as there is no support between the hubs because of the spacer. We found a couple cracked spokes, and we found one wheel had all six spokes one one side broken through after our last quarter-final match in Cleveland. If...I mean when we use these again, we'll definitely look to add spacers at the center of the wheel so that the hubs are not squeezed and stress isn't transferred to the spokes.
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
  #38   Spotlight this post!
Unread 01-04-2010, 22:04
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
i'm surprised that the engineers at andymark aren't fixing this sort of an issue for the current production. it seems like something a company should do if many customers are having the same issue
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
  #39   Spotlight this post!
Unread 02-04-2010, 01:10
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
These wheels have not been tested in an environment as abusive as this year's game. And it's not just these wheels breaking. teams are breaking wheels of many different types as well as axles, frames, and many other robot parts.
Andy and Mark are busy people, I find it remarkable that they manage to do as much as they do during competition season. I expect they will take a look at the Plaction wheel in the offseason and decide if it should be improved or if the issues are caused by abuse that the wheel just isn't, and won't be, designed for.
  #40   Spotlight this post!
Unread 02-04-2010, 01:39
AM does customer surveys after every season. These wheels lasted in all our applications without breaking.
  #41   Spotlight this post!
Unread 02-04-2010, 06:36
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Despite damages to some of our plaction wheels this season, I'll take it over anything else out there.
Its a replica of what we normally machined in the past using aluminum.
Due to time constraints this season, we elected to go with these. The simple fact that you can use either wedgetop or roughtop is awesome. It is a much cheaper solution and saves us time from making our own.
No one with mecanum, omnis and other types of wheels/tread has outpushed yet in our homezone. If anything, its other teams complaining about us in the act of trying to score goals.
Thank........you.............AndyMark.
  #42   Spotlight this post!
Unread 02-04-2010, 12:41
Chris is me's Avatar
AKA: Pinecone
My team had a sprocket failure in our drive at CT, and the bolts sheared before the Plactions sustained any damage whatsoever. I was seriously impressed. The Plactions are versatile, durable, cheap wheels that are better than any custom solution my team could have done. Unless we can make something lighter I don't see myself ever using anything else.
  #43   Spotlight this post!
Unread 02-04-2010, 14:49
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Go to this page and you will see several different kind of wheels that AndyMark has offered to the customers. Depending on the applications, the customers should choose from the collection.
We have a 8wd (all plaction wheels). We riveted the treads on the wheels and haven't had any of them come off. We were in 12 matches in Cleveland and the robot went over the bump at least twice every match (when coming down the impact was very high). I haven't seen a crack yet, but I forget to check again before we packed up the robot for Atlanta, so that will be the first thing on my to do list. Overall, I like the wheels; it hasn't given us any problem so far. Thank you AndyMark.
  #44   Spotlight this post!
Unread 02-04-2010, 15:56
LLogan LLogan is offline
Head Screw Tightener/Cheerleader
AKA: Logan
FRC #1261 (Robolions)
LLogan has a spectacular aura aboutLLogan has a spectacular aura about
Team 1261 uses four 6-inch plaction wheels on the robot. We have yet to encounter any problems of the tread slipping on the wheel. We have not riveted to the tread to the wheel either. The only thing that has happened to us is the screws holding the sprockets onto the wheels became bent, and that was our fault for not tightening them enough. They have survived two regionals and we have yet to see any sort of physical damage on the wheel.
Plaction and Omni wheels Edoc'sil Technical Discussion 7 21-02-2010 12:20
AndyMark Plaction Wheels Diserasta Technical Discussion 1 17-01-2010 22:20
Plaction Wheels : 250 Spacers/Review Ice Berg General Forum 2 17-01-2010 11:26
AndyMark Wheels Andy Grady Inventor 2 05-02-2007 16:49
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
