Go to Post I don't know how you can blame a robot getting stuck in the goal on the GDC. The field drawings showed all of the dimensions of the goals. If a team doesn't want to risk getting stuck then they need to plan around it. - JamesBrown [more]
Unread 27-03-2010, 15:56
Ted3299 Ted3299 is offline
Team 3299 Programmer
FRC #3299 (Warehouse Crew)
Team Role: Driver
Ted3299 is an unknown quantity at this point
Jaguar Problems with Movement
Hello,
Lately our jaguars have boon having problems with sharp movements and the like. Everytime we try to start to fast, go full speed, it will stop, but if we start slower, it works. The only thing I can think of is that a wire is getting diosconnected from something (pertaining to the jaguars) when it gets bumped to hard or starts too fast. This was going on for a while, but then we lost all function of a joystick connected to the right motor of the robot (only one motor and jaguar). Now, all the jaguars are working except for one, and its a grey jaguar with a yellow/orange blinking light.
Please help!
Unread 27-03-2010, 16:26
Re: Jaguar Problems with Movement
How's your battery? If the voltage drops too low -- which it can do if you're calling for sudden motor movement -- the system will be disabled.
Unread 27-03-2010, 17:11
Electrical Engineer
Rookie Year: 1995
It's hard to figure out what is happening unless you are very explicit in your description.
However, if only one motor is affected, you could have too large of a load on it and either tripping the circuit breaker or causing the Jag's internal protection to kick in.
Please try to explain exactly what you are seeing...
Mike Betts
As easy as 355/113...
Unread 27-03-2010, 19:31
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
You should also check the db37 from the CRio to the DSC, and the 3 wire PWM cables from the DSC to the Jaguars. It is very easy to damage the PWM wires, so you could try replacing the PWM wire to the disabled Jaguar.
Eric Haskins KC9JVH
Unread 27-03-2010, 21:02
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
We had the same problems, I'm pretty sure ours had something to do with the internals of the jags, we switched to victors and everything has been working since then
Unread 27-03-2010, 21:56
Terror Drone's Avatar
Terror Drone Terror Drone is offline
I am the Terror Drone, I like AL
AKA: Specs
FRC #1565 (Think Tank Tech)
Team Role: CAD
Terror Drone is an unknown quantity at this point
Their is one thing to watch out for, and we had this problem early into the build season as-well. The jag's were tripping out at 100%, it wasn't code nor a jag or CIM motor problem but the power going to the Digital side car from the Power distribution board. The 12v and 5v power LED'S were not on, and the jag's that were tripping out were not getting enough power. The best fix for this is to change the power cables for the DSC, and the WAGO connector, hopefully your DSC will get all the power it needs to keep all jag's powered.
All your base are belong to us.
Unread 27-03-2010, 22:53
Ted,
You are describing several different problems. As pointed out above, the DSC could have power issues, the multi pin connector could be loose or the Jaguar could be in protect mode. In the latter, the LED comes on red for 3-4 seconds while the output is disabled. Protect mode can occur due to high temps, high current, low power supply or limit switch jumper is open. It is also possible that you have metal flakes down inside the Jaguar.
You do not indicate that you are running PWM or CAN so a loose PWM connector can have similar issues. There is no LED on the Jaguar that flashes orange/yellow. There is a red/yellow flash that indicates a failure in the calibration mode.
Unread 27-03-2010, 22:58
Chris is me's Avatar
AKA: Pinecone
Out of curiosity, what is your gearing in your drivetrain?
Unread 23-06-2010, 14:25
cbpetrovic's Avatar
cbpetrovic cbpetrovic is offline
AKA: Mr. P
FRC #0166 (Chop Shop)
cbpetrovic is a jewel in the roughcbpetrovic is a jewel in the roughcbpetrovic is a jewel in the rough
Send a message via AIM to cbpetrovic
Originally Posted by Ted3299 View Post
Hello,
Please help!
We have seen this problem as well. From the indications of the LED on the jag, it's an overcurrent condition. This is documented in the user guide. Our machine uses the CAN bus for control; we will be testing to see if using PWM makes any difference (I don't think so).
C. B. Petrovic, Mentor/Team Advisor Team 166
Chairman's Award - UNH District Event, 2016
Entrepreneurship Award - Northeastern University District Event, 2015
Gracious Professionalism - Pioneer Valley District Event, 2015
Team Spirit - Pine Tree District Event, 2014
Entrepreneurship Award - University of New Hampshire, 2014
District EventMotorola Quality Award - LasVegas Regional, 2011
Chairman's Award - 2011, GSR
Gracious Professionalism - 2010, GSR
Innovation In Controls - 2009, GSR
Gracious Professionalism - 2008, Wisconsin Regional
Judges Award - 2007, GSR
Judges & Safety Award - 2006, GSR
Engineering Inspiration - 2003, GSR
Animation Honorable Mention - 2002, Nationals
Unread 24-06-2010, 11:18
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
My old team had this problem about 20 minutes later I remembered the previous year. The programmer was redoing his code all meeting to figure out the problem. He finally switched the battery, everything worked fine. So we repeated he thoughts. And there we go. The left drive train stopped dropping out.
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
Unread 24-06-2010, 12:13
cbpetrovic's Avatar
AKA: Mr. P
Chris_is_me: We are using 2 CIMs driving 4 wheels through a Banebots P80 12:1 transmission. This is the 1st year we haven't used 4 CIMs for drive.
Problem with watchdog and movement Ted3299 Programming 2 27-03-2010 17:20
Jaguar and Spike Problems huskyrobotics Electrical 8 14-02-2009 08:56
Jaguar and wireless problems. Team_2547 FRC Control System 1 26-01-2009 16:54
NEED HELP WITH CAMERA MOVEMENT nm4 Programming 3 10-02-2005 17:17
