Go to Post Welcome to ChiefDelphi a month before Kick-Off. This is an annual traditional experience for quite a few regulars. - synth3tk [more]
Unread 28-03-2010, 07:42
Spirator Spirator is offline
AKA: Munaum Muhammad
Spirator is a jewel in the roughSpirator is a jewel in the roughSpirator is a jewel in the rough
Banebots P80 Key Dimensions
Hey CD,
I was just wondering if anyone knew the dimensions for the machine key int he Banebots P80 gearbox. I looked at Banebots, but I'm not sure what they mean. We're trying to manufacture a steel key and I need to know the width of the key so it will fit into the gearbox shaft.
Thanks.
Unread 28-03-2010, 07:59
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
Re: Banebots P80 Key Dimensions
1/8 x 1/8 square
Unread 28-03-2010, 08:11
Thank you very much. Also, do you know how deep the key in the shaft is?
Unread 28-03-2010, 10:16
NOV8R's Avatar
AKA: Chuck Brant
FRC #1583
The key is 1/16 deep in both the shaft and hub for a total of 1/8. If your asking about how long, one inch long keys are used in hubs like those from AndyMark.
Banebots P80 Spirator Technical Discussion 1 13-02-2010 22:09
Restoration Key Ryutso NI LabVIEW 2 12-01-2010 18:44
banebots spc295 Motors 5 20-01-2009 23:10
New Banebots p80 Improvements Madwolvez Technical Discussion 14 04-05-2008 23:22
Spar-Key! Jacqui Sutton Thanks and/or Congrats 1 15-03-2003 23:48
