Go to Post Im ready for Christmas, then second Christmas!!!! - Raumiester2010 [more]
Unread 28-03-2010, 18:43
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
How many teams used default Java code?
I'm just curious.
Did your team use the FRC's default code for Java? What all did you add to it?
And yes, my team did. And being rookies, we didn't have much added to it. We maybe had a few variables that didn't do anything because I took them out half way through build season, and compressor handling.
What about you guys who used Java for programming this past season?
Unread 29-03-2010, 12:48
will_1359 will_1359 is offline
FRC #1359
will_1359 is an unknown quantity at this point
Re: How many teams used default Java code?
I hate to say this, but there was supplied Java code? the only supplied thing for java I used when programming our robot was the WPI library and the template that I found. Simple robot and autonomous and had to think up everything.
Unread 29-03-2010, 13:39
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
There was some code in the examples section that included a "default robot". We didn't use it, but it can be a good start, but rather started with a circletrackerdemo example to expand our code from.
I don't need a signature.
Unread 31-03-2010, 16:12
Team#2057-Vegas's Avatar
Team#2057-Vegas Team#2057-Vegas is offline
Team2057LasVegas
AKA: Justin Major
FRC #2057 (AV CyberBulls)
Team#2057-Vegas can only hope to improve
We used java this year because it was the only coding our new programmer could do. We are having a few issues though and now continuously after trying the "no app fix" that has been mentioned to us. We are continuously getting the "NO ROBOT CODE" message and it has wasted our past 3 weeks. Competition is tomorrow. Have you had the same problem? If so please tell.
Good luck on your competition if you have yet to have it.
AV CYBERBULLS
Justin Major
2057 Team Leader
"We will kick you off our pasture" -- 2057 Motto
Unread 31-03-2010, 17:13
AKA: Dan
Can you provide more details? So here are the steps to test it:
The following assumes that you have completed all updates, installed the FRC plugins for NetBeans, and have your cables/robot network set up correctly.
In NetBeans, go to File->New Project
Scroll down to Samples and open the FRC Java folder.
Look for DefaultCodeProject.zip and double click it.
Give the project a name of some sort.
The new project SHOULD be your main project (the main project is in BOLD in the Projects pane). If not, right click your newly created project and click on "Set as Main Project".
Ok now you have a Java project.
To Deploy:
Either hit the Green arrow at the top of the GUI or hit F6. This builds and deploys the Main project to the robot.
At some point you should see something like this:
Connecting FTP @10.20.57.2
Indicating that it is trying to connect to your robot. Once it is connected it will erase and upload the newly build Jar file.
Try this and report what happens.
Unread 31-03-2010, 19:27
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Well I used the circle tracker demo code, but expanded on it and just took out the target tracking...
Unread 01-04-2010, 09:52
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
AV CYBERBULLS
I just want to double-check that you're still having a problem. In "http://www.chiefdelphi.com/forums/showpost.php?p=946038&postcount=23", someone posting as you said problem was fixed (bad bridge?).
If still a problem:
- At the competition, bring this up immediatly with the robot inspectors or other competition staff. They may have someone with Java experience, or can track down a team with Java experience to help.
- Double check network settings of your development machine.
- Can you ping the cRIO from the PC?f ftp to the cRIO?
- Make sure the netmask of the PC is 255.0.0.0.
- Please post the NetBeans output from a download/deploy/run attempt.
- Is the ftp failing? Or failing to connect after rebooting the cRIO?
Also, I think the "no app fix" was more of a Labview thing. I believe that C++ and Java robots run as startup code that is not disabled by the "no app fix".
Good luck!
Unread 05-04-2010, 18:17
LukeS LukeS is offline
4272 mentor, 1024 alumnus
AKA: Luke Shumaker
FRC #4272
LukeS is an unknown quantity at this point
We examined the circle tracker when we were looking into adding a camera to our system (something we didn't end up doing), but no,we in no way used any of the sample projects.
How do I load the default code? HarryScheiner C/C++ 7 11-02-2009 11:52
How Many Have You Used? Robots_R_Us FIRST Tech Challenge 6 25-08-2006 22:32
How long does it take you to load the default code? vegasmcse Robotics Education and Curriculum 10 03-11-2003 21:41
how many of u actually used the stacker if u had one? HolyMasamune General Forum 21 14-04-2003 13:12
How many teams.... archiver 2001 0 24-06-2002 04:03
