Re: Opinions: The importance of elevation/suspension
Something interesting to bring up. At the SBPLI Regional none of the 6 robots in the finals could hang or elevate themselves.
Identical situation at Buckeye if I remember correctly, although not true at the Boilermaker Regional. Honestly though, at Buckeye, there were very few robots that could hang that were really any good for anything else.
One thing that i noticed in Boston is that in finals (especially when double teamed) we were blocking a lot of shots, easily more than two in the last 20 seconds. And because we were in the defensive zone we would have had to leave the zone before the last 20 seconds to avoid contact with the other alliance if they tried to hang.
~DK |
How did they do that while remaining elevated?
I would say that being able to elevate is a worth while mechanism if the robot can not easily make up the 2 points of elevation. At Traverse City BOB could have possibly made it into finals if we had a working arm. We lost the deciding match of semi finals by 2 so it is debatable if we could've actually won in 4th round of semi final match.
#7
Our drivers couldn't see if they where completely clear or if there would be contact. They where too afraid of making contact in some way and damaging ourselves sine our electronics are mounted pretty close to out top.
#8
In Ann Arbor finals match 3, our two points via hanging won us the Regional, and sent us off to the Michigan State competition.
I believe the first time 1448 and 1328 hang together the final score of the match was 5-5... so they tied the match just via that.' So, yes, IMHO hanging will be what separates good teams from great. Teams that can have others suspend off of them (Us and 1448 as far as I know) will be in great demand once they can do that consistently. One of the teams in the final game will probably have a team that can suspend someone else on the team, and that will be why they have gotten that far. |
#9
I disagree, I don't think suspensions will be very common at Championships if they happen at all and I don't think there will be a single suspension on Einstein or even in the division finals
#10
Hanging is useful if more than one team in your alliance can do it; but if only one can then it's not really enough of a difference to be a major swing. It's harder for two teams to score four points in those twenty seconds via goals than it is for one team to score two points, because they tend to get in each others' ways.
#11
How important is hanging? Do a little math.
On average, how many points are going to be scored per match? Then, calculate how often they'll be scored. For instance I'd wager saying that each team scored 2-4 points per match during week one (in fact that's probably a bit high). It's pretty simple to see that hanging in that context is HUGE. In the fourth week, there were routinely scores up in the 8-10 point range during eliminations. That 2 points might save you once or twice, but it's a lot less important. At nationals? It may be (on average) even less important, as robots improve and scoring improves. It's a risk vs. reward thing. Do the math on the rate of scoring, and figure out which is more important - taking the time to hang or trying to score another 2 balls. My guess is that by nationals unless you hang in under 10 seconds every single time, then mathematically it's a wash. |
#12
You also have to take into account the availability of balls.
Let's figure that an alliance has two robots playing offense and one on defense. There might be a point in the last 15-20 seconds of the match where they just scored a significant number of balls they control and will have to wait a while for the balls to be put back into play, controlled, and then scored. It would be much easier for the robots to then just turn around and hang on the tower. That timing might just the difference between a finalist and winner. While I agree that hanging will be less valuable in the Championship eliminations, as ball scoring becomes more prevalent, I think we'll definitely see it a few times. |
#13
At philly, both alliances in finals didn't have hangers either. However, all of the hanging alliances lost in semis by very slim margins in matches that could have gone either way (we got knocked out by 1 penalty point).
For us, during qualifiers we usually won by big margins (not the best thing for QPs) and hanging turned mainly into a "seal the win" thing and also showing off to the scouters. For elims, our midfield parter, 1640, could do some decent scoring from midfield, and could jump the bump to offense, we would swap zones to go for the hang. An important factor though was 87 being able to hold down the opponent's goals and keep the score opponent score from jumping while we had no active midfield bot. |
#14
). While 846 did hang successfully, I was told by our human player and another alliance member that our opponents used the opening to score 6 shots. Final score: 13 to 10, them. If robots on your alliance are going to hang, they should not be playing goalie. They should be in the front or neutral zones. |
| The importance of clean wiring | sanddrag | Electrical | 20 | 14-02-2006 20:04 |
| Importance of the Rookie Chairman's | Barry Bonzack | Chairman's Award | 5 | 28-02-2005 14:54 |
| Elevation of the Tetras? | Flynn | Rules/Strategy | 8 | 24-01-2005 18:56 |
| The Importance of Sound | ComBBAT_Albrot | 3D Animation and Competition | 8 | 09-03-2002 20:33 |
