Re: How Do mecanum wheels handle the bumps?
All seriousness aside, where did you get the 71% number? ~ |
Think about a free body diagram for physics. You may have 9 N of force in one direction and 2 N in the opposite direction, so you are letting off 11 N of force, but you only have a net of 7 N in the forward direction. Mechanum wheels seem nice in theory, but if I'm not mistaken, a team has never won nationals with a mechanum drive. If they meet tough defense they can easily be out pushed. They're good for qual matches with low defense, but I'll be interested to see how they fair in elims in Atlanta. Last edited by sgreco : 29-03-2010 at 09:48. |
But that's beside the point. The question on the table is whether or not "only 71% of the output torque is transmitted in the direction of travel" when the bot is going straight forward (or backward). Quote:
My team uses the 6" version of AndyMark Mecanum wheels (the ones with the lower coeff of friction), and we have no problems going over the bump. The only problem to date (that I'm aware of) is when our mentor was driving the drive train during the build season, and he drove the robot full speed into and over the bump. We lost one roller; considering the way he was driving it I'd say it did 3x better than expected. |
If mecanum drive trains lack pushing power, why not have the opportunity to lock the rollers, effectively turning mecanum into 4 wheel tank drive?
While I was away in Thailand during build season, 190 did just that. |
#7
Ty -- it would be possible to pull that off, but would takea lot of research and testing (off-season project anyone?) where as, in my opinion, mecanums are still good for defense, but not the pushing kind. They're much better for the manueverable, get-in-the-way kind
#8
Edit: "Disclaimer" I was in no way involved with 190's robot this year so, essentially, this is just me analyzing another cool robot I saw at a regional. Last edited by Ty Tremblay : 29-03-2010 at 11:29. |
#9
All the forward torque applied to the wheel is transmitted to the carpet. The torque is not reduced by cos(45). Quote:
#10
Mecanums have the same math / efficiency setups as normal "omni" drives, with the same vector math. You'll pretty quickly figure out where 71% comes from. |
#11
The rollers do spin noticeably when you're driving straight forward. This is where the obvious loss of pushing power manifests itself. If you go through the vector analysis of how much torque is pushing in which directions for an ideal rectangular-layout mecanum or omniwheel drivebase, you find that ~70% goes to movement in the forward direction, and ~70% goes to trying to squash or stretch the frame in the sideways direction. All the torque is available in the diagonal direction. The torque in the forward direction is only cos(45) of the maximum. |
#12
anyone can respond to this |
#13
190 designed a mecanum wheel with double internal yokes (this means that the end pieces of the rollers are cantilevered, and the middle piece is supported on both ends) that is driven like any other mecanum wheel via sprocket on one side. On the other side of the wheel, however, is a friction plate with a face profile that matches the side of the rollers closest the the wheel's axis of rotation. When the friction disk is pressed into the rollers via pneumatic cylinder, the disk prevents the rollers from spinning while allowing the wheel to rotate. When they want to return to mecanum drive, they disengage the friction plate. I will now attempt to illustrate this on my computer... EDIT: Here's the pic. ![]() Last edited by Ty Tremblay : 29-03-2010 at 14:59. |
#15
This year as a mid fielder, I think we play very aggressive defense and can push people around with our mecanums. Also defense isn't always about having the ability to just push people, there is more to it. -Clinton- |
| How to mount mecanum wheels | Sam2197 | Technical Discussion | 6 | 16-12-2008 18:32 |
| pic: Figuring out the mecanum wheels | Rapt0r9 | Extra Discussion | 4 | 25-01-2008 19:55 |
| Mecanum Wheels is it good fin the Pits | yara92 | Technical Discussion | 18 | 21-12-2007 00:14 |
| How Do Mecanum Wheels Work? | SPARKY1688 | Kit & Additional Hardware | 9 | 08-01-2007 23:39 |
| Split topic - How many channels can the current (2004) Oi's and Rc's Handle? | Elgin Clock | Control System | 6 | 02-01-2005 14:02 |
