Go to Post We have not always been a winning team but we have always tried to be a quality team. - WynS [more]
Unread 22-03-2010, 23:05
FIRSTgirl675's Avatar
FIRSTgirl675 FIRSTgirl675 is offline
AKA: Stephanie
FRC #0675 (Tech High Robotics)
FIRSTgirl675 will become famous soon enoughFIRSTgirl675 will become famous soon enough
Re: Advanced tools in the workshop (Mill, Lathe, Welder etc.)
Originally Posted by Dick Linn View Post
I don't know if you can get used equipment. As far as new low-end Chinese lathes and mills, you might look over the items and prices here:
http://www.grizzly.com/products/cate...spx?key=460000
http://www.grizzly.com/products/cate...spx?key=480000
If you are looking into investing into a lathe we (675) have a Grizzly Lathe, and we are always having problems with it, probably because it is low-end and made in China. It seems as if it is broken and needing to be fixed every other month or so. I would recommend getting a lathe because of the advantages of having one, but I would get one from a different brand.
Unread 23-03-2010, 11:01
Dick Linn's Avatar
no team (Synergy)
For a TIG welder, an inverter-based unit would be more portable and you can get by with a bit less amperage. 200-250 Amp class is nice but they get expensive. We picked up an older Syncrowave 250 for $850. but it's a real power hog and weighs nearly 400 pounds.
Here's a TIG amperage calculator: http://www.millerwelds.com/resources...calculator.php
Here's a TIG unit that is simple to operate. Hobart has an equivalent. http://www.millerwelds.com/products/tig/diversion_165/
This is a great unit, but over twice the price: http://www.millerwelds.com/products/...ty_200_series/
This welder is prices somewhere between the two. It may be available in other countries since it is a rebadged unit from Japan.
https://www.mythermadyne.com/thc/en/...tProductDetail
I'm surprised to hear of the Grizzly lathe breaking all the time. I know they aren't top-notch, but that just doesn't sound right.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 29-03-2010, 00:13
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
As a rookie mentor and skilled machinist, I have been frustrated by the lack of a lathe and the sad excuse for a mill (no auto-feed on any axis) in our school's shop. Fortunately, we were just offered a 14" swing lathe as a donation. A few suggestions for setting up lathes, mills, and other rotating metal cutting machinery (if budget can handle them):
1) Get variable speed drives - most unskilled students will not deal with pulley swapping speed adjustments.
2) Lathes must have quick change tooling - preset tools are almost essential for unskilled H.S students to be minimally productive.
3) Don't skimp on tooling - our basic mill is rarely used because the vice is always being removed to use on a nearby drill press, and students consider that it's too much work to swap back. A full compliment of dedicated tooling, readily accessible, is essential for for making good use of any advanced machine tool.
4) Teach the science of metal cutting - understanding the basic principles of metal cutting should be a prerequisite for students to use the more advanced machines. Things like determining proper cutting speed for different materials should be understood before equipment access is granted.
-Dick Ledford
Unread 29-03-2010, 12:37
MarkoRamius1086's Avatar
MarkoRamius1086 MarkoRamius1086 is offline
Robot Inspector
AKA: "Petrie"
FRC #1086 (Blue Cheese)
MarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to behold
I am a machinist on my team, and I would like to put my input in on what the most valuable tools are and what is used the most:
1. Manual Mill- Allows for accurate parts to be made, which is vital in competition.
2. Belt Sander- Keeps manufactured parts safe!
3. Lathe- Crucial for a custom and reliable drive system.
4. Bandsaw- Makes for quick raw material manufacturing.
HEROES DIE, BUT LEGENDS LIVE FOREVER!
[OCCRA]: OCCRA OCT-NE 10/14/09 Advanced Workshop PDF marccenter OCCRA Programming 2 07-12-2009 13:56
Drill/Mill or Lathe/Mill attachment for small shop area Coach Norm General Forum 22 16-09-2009 15:59
lathe turning wheels- is it against the rules? mrnoble Rules/Strategy 6 22-01-2009 19:21
EMC linux + CNC mill + CNC Lathe Leav Technical Discussion 8 09-11-2008 23:08
Where can I find lathe and fillet tools in 3DS Max? laungani26 3D Animation and Competition 2 16-01-2007 16:34
