#16
Re: Advanced tools in the workshop (Mill, Lathe, Welder etc.)
For a TIG welder, an inverter-based unit would be more portable and you can get by with a bit less amperage. 200-250 Amp class is nice but they get expensive. We picked up an older Syncrowave 250 for $850. but it's a real power hog and weighs nearly 400 pounds.
Here's a TIG amperage calculator: http://www.millerwelds.com/resources...calculator.php Here's a TIG unit that is simple to operate. Hobart has an equivalent. http://www.millerwelds.com/products/tig/diversion_165/ This is a great unit, but over twice the price: http://www.millerwelds.com/products/...ty_200_series/ This welder is prices somewhere between the two. It may be available in other countries since it is a rebadged unit from Japan. https://www.mythermadyne.com/thc/en/...tProductDetail I'm surprised to hear of the Grizzly lathe breaking all the time. I know they aren't top-notch, but that just doesn't sound right. |
#18
As a rookie mentor and skilled machinist, I have been frustrated by the lack of a lathe and the sad excuse for a mill (no auto-feed on any axis) in our school's shop. Fortunately, we were just offered a 14" swing lathe as a donation. A few suggestions for setting up lathes, mills, and other rotating metal cutting machinery (if budget can handle them):
1) Get variable speed drives - most unskilled students will not deal with pulley swapping speed adjustments. 2) Lathes must have quick change tooling - preset tools are almost essential for unskilled H.S students to be minimally productive. 3) Don't skimp on tooling - our basic mill is rarely used because the vice is always being removed to use on a nearby drill press, and students consider that it's too much work to swap back. A full compliment of dedicated tooling, readily accessible, is essential for for making good use of any advanced machine tool. 4) Teach the science of metal cutting - understanding the basic principles of metal cutting should be a prerequisite for students to use the more advanced machines. Things like determining proper cutting speed for different materials should be understood before equipment access is granted. -Dick Ledford |
#19
I am a machinist on my team, and I would like to put my input in on what the most valuable tools are and what is used the most:
1. Manual Mill- Allows for accurate parts to be made, which is vital in competition. 2. Belt Sander- Keeps manufactured parts safe! 3. Lathe- Crucial for a custom and reliable drive system. 4. Bandsaw- Makes for quick raw material manufacturing. |
| [OCCRA]: OCCRA OCT-NE 10/14/09 Advanced Workshop PDF | marccenter | OCCRA Programming | 2 | 07-12-2009 13:56 |
| Drill/Mill or Lathe/Mill attachment for small shop area | Coach Norm | General Forum | 22 | 16-09-2009 15:59 |
| lathe turning wheels- is it against the rules? | mrnoble | Rules/Strategy | 6 | 22-01-2009 19:21 |
| EMC linux + CNC mill + CNC Lathe | Leav | Technical Discussion | 8 | 09-11-2008 23:08 |
| Where can I find lathe and fillet tools in 3DS Max? | laungani26 | 3D Animation and Competition | 2 | 16-01-2007 16:34 |
