Go to Post I think it's great the way people involved in FIRST always try so hard not to argue. It's a good sign that all the talk of Gracious Professionalism is working. - BaldwinNYRookie [more]
  #33   Spotlight this post!
Unread 29-03-2010, 12:42
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: How Do mecanum wheels handle the bumps?
http://www.chiefdelphi.com/forums/sh...6&postcount=33
Refer to RobotA mentioned in the thought experiment in the post at the link shown above.
If the motor is providing a torque of 40 in-lbf to a wheel, and the wheel is not slipping, then the carpet MUST be reacting with a force of 10 pounds (for a 8" diameter wheel) in the plane of the wheel, acting against the wheel trying to push it forward. The forward component is 10 pounds (the exact same forward component you would get with a standard wheel). It cannot be otherwise.
And yes, with the mecanum wheel there are additional vector forces at play. But they do not subtract from the 10 pounds. I encourage those of you who are using the "vector" argument to think a bit more about how the vectors are created.
I will concede in that the split second before the rollers start to slip there is an instant the wheels put all force directly forward. Yet this split instant of an isolated experiment doesn't translate to assisting a driver in pushing due to the dynamics of the holistic system. The driver doesn't go up to something, stop, and THEN push the object. The only scenario in which this may minutely apply is in a situation of pinning. Yet even then, the instant the robot moves it turns into a dynamic situation -- the rollers slip, the tractive forces only translate 70% torque, and thus the bot remains pinned.
2017 Scoring Model
CAD Library | GitHub
How to mount mecanum wheels Sam2197 Technical Discussion 6 16-12-2008 18:32
pic: Figuring out the mecanum wheels Rapt0r9 Extra Discussion 4 25-01-2008 19:55
Mecanum Wheels is it good fin the Pits yara92 Technical Discussion 18 21-12-2007 00:14
How Do Mecanum Wheels Work? SPARKY1688 Kit & Additional Hardware 9 08-01-2007 23:39
Split topic - How many channels can the current (2004) Oi's and Rc's Handle? Elgin Clock Control System 6 02-01-2005 14:02
