Go to Post The problem was too many penalties with too much room for judgment. - dbSparx [more]
View Poll Results: which holonomic drivetrain is the best???
mecanum (small rollers are 45 degrees to main wheel) 22 31.43%
omni (small rollers are perpendicular to main wheel) 7 10.00%
crab drive/swerve drive (wheels turn in order to change direction) 45 64.29%
other 10 14.29%
Multiple Choice Poll. Voters: 70. You may not vote on this poll
Unread 29-03-2010, 13:04
NyCityKId's Avatar
NyCityKId NyCityKId is offline
That Weird Kid
AKA: Andre Dunkley
FRC #1601 (Quantum Samurai)
NyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to behold
Send a message via AIM to NyCityKId
which holonomic drivetrain do YOU think is the best any why???
this is a poll between crab drive/swerve drive, mecanum drive, and omni drive (small wheels are perpendicular to main wheel). feel free to list any other holonomic drive u might know about or prefer.
also feel free to IM me
Unread 29-03-2010, 13:06
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: which holonomic drivetrain do YOU think is the best any why???
No poll.
EDIT: Didn't know if you knew it wasn't there. Thanks!
1058 PVC Pirates 2016 - xxxx
Unread 29-03-2010, 13:09
NyCityKId's Avatar
That Weird Kid
AKA: Andre Dunkley
Originally Posted by BrendanB View Post
No poll.
the poll is up now .... i had to post the thread before i put up the poll... sorry
Unread 29-03-2010, 13:10
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Kiwi
___________________
- Tennyson, Ulysses
Unread 29-03-2010, 13:12
NyCityKId's Avatar
That Weird Kid
AKA: Andre Dunkley
Originally Posted by Daniel_LaFleur View Post
Kiwi
why???
Unread 29-03-2010, 13:15
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Asking which one is best is a bit difficult because there are many factors involved like, Cost, Build Difficulty, Programming, Control, etc...
Personally, the only type of Omni-Drive I would consider is a Swerve. The upside to a swerve drive is that you have full traction, which is something that Holonomics and Mecanums lack. The downside to a swerve is that it's difficult to build and can be a pain to program and drive.
-Dustin Benedict
Unread 29-03-2010, 13:18
NyCityKId's Avatar
That Weird Kid
AKA: Andre Dunkley
well stated.... point taken
Unread 29-03-2010, 13:19
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
I think that a 360 degree with all four pivots turn independently moving swerve drive is best since that's what we are driving this year.
But I have to give very high marks to the omni/twitch hybrid I saw at Philadelphia. (Sorry I've spazzed on remembering your team number/name).
Each corner was a pair of Andy-Mark Omni's bolted together so that there was a continuous set of rollers around the circumference. They were set up in a standard 4 motor drive.
Two opposite corners were mounted on Delrin pivots. The wheels could be turned 90 degrees by two small pneumatics.
Best of both worlds: tank drive with good forward / backwards grip but a little slip to allow easy turning and the ability to flip into a omni-bot for strafing and translation movements.
A very clever solution to allow omni-bot flexibility with a low center of gravity and clearing the humps.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 29-03-2010, 13:23
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I would say it's highly dependent on the task.
There are complexities with crab/swerve that aren't present in the others - with a short build season like we have, it may be too complex to accomplish (when you consider everything else you want to accomplish). Then again, they provide more pushing power in any direction than the others - is pushing power important enough to accept the additional risks that come with the complexity of crab/swerve? Do you have the weight available for crab/swerve (as it is typically heavier than other drive systems)?
Having Mecanum wheels on the corners works great, so does having omni wheels on each of the 4 sides. But if you need to go up a ramp, an omni wheel setup like that isn't going to work, while mecanum will. And just taking the omni's at 45 degrees to the frame in the corners is basically mecanum, only with the added complexity of needing to mount everything at 45 degrees to the frame.
So before you can really get good answers, you have to define the task and the associated parameters. Each system is good, but different systems will excel at different tasks and with different parameters. One of the key challenges with building a robot for FIRST isn't identifying a single "best" system and perfecting it to use year after year. It's in identifying what the best system would be for a given task and working in a very short time period to perfect it.
Unread 29-03-2010, 13:27
thefro526's Avatar
Mentor for Hire.
You're talking about 1218, I believe they won and award for their drive.
-Dustin Benedict
Unread 29-03-2010, 13:52
Best for what?
(I don't consider swerve drive holonomic.)
Unread 29-03-2010, 13:55
MarkoRamius1086's Avatar
MarkoRamius1086 MarkoRamius1086 is offline
Robot Inspector
AKA: "Petrie"
FRC #1086 (Blue Cheese)
MarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to behold
You took the words right out of my mouth!
HEROES DIE, BUT LEGENDS LIVE FOREVER!
Unread 29-03-2010, 13:57
1) What are the requirements of the game?
2) What can you build and program in the 6 weeks?
If the drive you choose fits both, it is the best.
If I had to choose, I'd go with mecanum, because it's relatively easy to swap out the mecanums for some standard wheels and spacers. Swerve, you have to lock the modules (depending somewhat on what arrangement you have).
BTW, Kiwi Drive is 3 omni wheels arranged in a triangle.
Unread 29-03-2010, 15:05
ALTrammell818 ALTrammell818 is offline
Strategy Captain and Drive Coach
AKA: Aaron
FRC #0818 (Steel Armadillos)
Team Role: Tactician
ALTrammell818 will become famous soon enoughALTrammell818 will become famous soon enough
Send a message via AIM to ALTrammell818
Mecanum drive has proved quit useful to us this year.
Unread 29-03-2010, 16:27
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Octo-canum. Name inspired by "nonadrive"
Who do you think is the best bet to win the Chairman's Award at the Championship? Koko Ed Chairman's Award 58 29-04-2005 16:39
which team do you think has best drivers Masterfork General Forum 41 12-04-2005 10:51
Which team do u think used firsts gearboxes the best. 18voltMilwauke General Forum 5 17-04-2003 12:01
Which Robot Do You Think should be King Of The Hill mtaman02 General Forum 58 14-04-2003 12:35
why you robot is the best rcubes85 General Forum 4 18-02-2003 07:22
