Go to Post And, if you don't know what something means, say so, we'll be happy to explain. - DonRotolo [more]
Unread 29-03-2010, 12:45
bobrenjc93 bobrenjc93 is offline
FRC #3061 (The Federation)
bobrenjc93 is an unknown quantity at this point
Send a message via AIM to bobrenjc93
Tips to make your robot look good.
I have realized that most robots, even the more complex ones like 16, 148, and 114, all look relatively good. You rarely see wires scattered all over the robot, and in most cases, you really don't see any wires at all. So my question is: How does your team design and build a good looking robot?
Unread 29-03-2010, 12:59
robself705's Avatar
robself705 robself705 is offline
Team Leader / Mechanical
AKA: Rob Self
FRC #0706 (Cyberhawks)
robself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to all
Re: Tips to make your robot look good.
The first thing in my opinion that differentiates a "good looking robot" from a "not as good looking robot" is the use of machined parts. Finding a sponsor that can cut out parts for you is a very important team goal. We are fortunate enough to have a CNC plasma cutter available for use at our school. We try to use it as much as possible because this allows for very precise design of parts. The first step to getting machined parts is having a student or students who know how to use CAD software. Not only does this allow for quick prototyping and proof of concept but it also allows quick editing and very easy "export to reality." Once the part is completed and works correctly in the CAD software all you need to do is send it to a sponsor (even via e-mail) and they can cut it out in a day or two. This allows for very efficient build time. Theoretically you could even build your whole robot in CAD, watch it drive around and work and then send it to a sponsor to cut it out, get the parts and simply assemble it with bolts. I know that this is what 217 and 148 do. If you look them up, they have beautiful robots. Everything is fully drawn up in CAD, tested for proper function and then sent away to be cut. If you can't find a sponsor to cut out parts for you. Try to make your robot as shiny as possible. When I say this, I mean make everything as polished and clean as possible. This means stay away from lots of visible hack saw cutting, glue, tape and visible "oops I accidentally drilled in the wrong spot" holes. Clean lines, symmetry and as little "jank" as possible make a beautiful robot. I consider "jank" to be something that looks like it was thrown together without thought and planning. Finally, wire everything at the end and at one time. Planning the wire routing should be done after everything else is done, this eliminates the "lets move this wire over here because its in the way now." Mount all of the jaguars and victors in the same spot and close to the power board. This means less wiring over all and all of the similar wires can be zip tied together into sections. Planning makes a robot looks good.PLAN PLAN PLAN. And then of course add some LED's at the end (check out ebay, search for led strip, search by lowest price and order a 40 in strip for $6 shipped directly from China. It will take two weeks to arrive however).
Let me know if you have any more questions.
Rob Self-
Cyberhawks Team 706
Hartland, WI
Our breakaway bot in action (13-3-1): Team 706 in action
Unread 29-03-2010, 13:06
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
  1. Prototype before final design
  2. Design before build
  3. Build to the design
  4. Accuracy and neatness counts
I'm on the electrical team so we run wires neatly and together. We use #10 wire for primary power so an extra inch or two won't make an electrical difference. Label everything, cable ends, connection points, Jag/Spikes/etc. Zip tie the power wires into neat bundles and the control wires into different neat bundles. Zip ties every 3-4" keep things neatly together.
Devices like Jags are mounted on panels close to their motors. This year the 8 Jags are mounted on the sides of the robot in a neat row.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 29-03-2010, 13:23
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
We won the 2010 - Xerox Creativity Award at the Denver Regional. Our robot has no CNC machined parts nor are there many metal parts in general. The main material used in its construction is 1/2 inch baltic burch plywood. It does have holonomic drive, and several other unique features, but the best way to describe it (and the words used to describe it in the award) is "simple and elegant". Your grandmother knows what those words mean and can identify a good looking robot when she sees one.
Unread 29-03-2010, 13:31
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Personally, I'm a big fan of colorful robots.
http://www.chiefdelphi.com/media/photos/34364
-Dustin Benedict
Unread 29-03-2010, 13:45
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Lots of CAD design revisions, a strict attention to detail, a high standard for manufacturing quality, powder coat, anodize, tinted polycarb, and vinyl cut stickers.
Unread 29-03-2010, 13:56
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
I really have to disagree with robself705. Machined parts can make a robot look good, but put those same parts in the hands of another team, and the robot won't look nearly as good.
The biggest thing you need to have a robot looking good is attention to detail, from the beginning through the end. If you're putting something together and you finish by saying "well, that's good enough", it's not going to look all that great, although it may function just fine.
For electrical, wire routing is incredibly important, yet most teams don't spend any time on it and end up with a "rats nest" of wires. To alleviate this, there are a couple of practices every team can do that will really clean things up:
- Making everything co-located as much as possible (on one board, for example) will allow you to spend the time to route the wires properly and secure them with some simple, cheap plastic p-clamps. You can get nice, neat, straight wire runs that way.
- Before you put any wires in, determine one or two "wire highways". essentially, bundle the wires together as much as possible (simple zip ties at regular intervals work great, or you can go with a braided sleeving or, if possible, plastic wire ducting), and branch off that main bundle when needed.
- Getting wire for your power needs that has a relatively stiff jacket lets you put some nice, semi-permanent bends in the wire, which can help a lot with routing.
Unless you really want to show something off, you can generally cover most things. This year, our robot has a nice aluminum hood that really makes it look nice (not that things beneath look bad).
Work with a professional print shop for your sponsor sticker, and learn the proper way to apply it to avoid air bubbles. If you have enough room, use a single sticker. A nice, bright sticker with crisp edges and cool logos really helps.
And finally, do some searching on the web and figure out how to make your materials really look good. If you're using wood, you can paint or stain it to look even better. For aluminum, you can spend some time working with it to really make it shine with bright, neat circles in it (polishing compound, a circular wood block, and a drill press). After a full build season, even the best of teams end up scratching up their materials... time for "beautification" at the end really makes things pop.
Unread 29-03-2010, 14:29
run the trap!!!
Team Role: Human Player
Carefully design your robot in CAD.
Then: poorly machine the parts (make sure to drill a lot of unnecessary holes). Do a terrible job welding (the key here is to make sure nothing comes out 90*, while maximizing burnthrough and blobbyness). Duct Tape. Use it wherever possible. When wiring, make sure to use as much wire as possible and tie it in great nots all over the bot.
...Then cover everything in plastic panels so no one notices
What? You think I'm joking?
-Philip J. Fry
Unread 29-03-2010, 15:49
fordchrist675's Avatar
fordchrist675 fordchrist675 is offline
"Wilfordito"
AKA: Wilford Jay Harris III
FRC #0675 (Technology High School Robotics)
fordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to all
Send a message via AIM to fordchrist675 Send a message via MSN to fordchrist675 Send a message via Yahoo to fordchrist675
675 won the 2010 Xerox Creativity award at SVR. We have a couple mentors that can CNC parts, but primarily our robot is student built. A big thins is measure twice cut once. We won for being the only team there with a ramp. But we thrive on building great robots with little sponsorships or anything. I think its really a design and an ability to work together as a team. Combing the experience of seniors and mentors with the ideas of newer members allows for an efficient work environment. It doesnt hurt to powder coat everything though.
It's not by how much you win, it's how you win. Respect your enemies, otherwise your no better than them which if you think about it that's true because we are striving for the same thing. To be FIRST
2010 SVR Creativity Award
2010 SVR Regional Finalists
2010 SAC Innovation in Control Award
Unread 29-03-2010, 16:54
MarkoRamius1086's Avatar
MarkoRamius1086 MarkoRamius1086 is offline
Robot Inspector
AKA: "Petrie"
FRC #1086 (Blue Cheese)
MarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to behold
Keep all the electronics organized and compact. The one thing that most people blurt out first when they see our robot though is "POWDER COAT"!
Powder coat or Anodizing is really nice unless you're looking for a more metallic look. I remember this year 75 has a really nice shiny aluminum look.
(I mentioned anodizing because in Atlanta last year, I saw 148's robot... I was speechless. The black anodizing was so insane I could feel my jaw drop. If you want to model your looks after a team, 148 is a great place to start!)
HEROES DIE, BUT LEGENDS LIVE FOREVER!
Unread 29-03-2010, 17:00
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Anodizing, powder coating, and CNC machining can really improve the looks of a robot, especially when seen up close. But the key to making a good looking robot is careful planning, which includes the schedule, so you can take the time to do a neat wiring job, paint the parts (if you can't manage to get them machined/coated/treated), and generally make it look finished.
Last year our robot looked pretty good, it was made mostly of plywood, which we spray painted. A couple of coats of spray paint, sanded between coats, can be hard to distinguish from powder coating!
Unread 29-03-2010, 17:40
"Wilfordito"
Also a designed layout for electronics condensing and organizing helps make it look professional and efficient. It may be tedious but its well worth it.
Unread 29-03-2010, 18:06
Vermeulen's Avatar
Vermeulen Vermeulen is offline
I have too much free time now
AKA: Tom Vermeulen
FRC #1306 (BadgerB.O.T.S.)
Vermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to all
Added bonus to having a nice and tidy electrical board: it takes way less time to pull the electrical stuff, or to fix a problem. It once took me 10 minutes to pull our electrical board while testing, with two people helping me look for wires. Also, try to go away from the "box on wheels" design that many teams are guilty of (mine included). It doesn't even need to be a fancy cnc-milled one-piece aluminum shell. For example, the top section of 2194's robot this year was made out of die-cut cardboard with a design printed on one side.
Congratulations Ben Senson on winning the 2012 Wisconsin Regional Woodie Flowers Finalist Award!
2012 Wisconsin Regional Semifinalist
2012 Wisconsin Regional Engineering Inspiration Award
2011 Wisconsin Regional Innovation in Control Award
2010 Wisconsin Regional Chairman's Award
2010 Wisconsin Regional Quarterfinalist
2010 Curie Division Quarterfinalist
Unread 29-03-2010, 18:41
Billfred's Avatar
Billfred Billfred is offline
Minor counterpoint: Organized, then compact. I've been on teams that have done "and", and "then" works out much, much better when you're trying to fix it.
In the absence of a lot of time or resources back in my 1618 days, I had to pull a few tricks of my own. Among my favored tricks:
2007-2008
Plotter-printed graphics. Laminating them worked decently in 2007 (and may be all you need in years where there's no reaching outside the frame). In 2008, for fear of pokey robots (or bumbling students), we spray-adhesived them to lexan for more protection. I printed 1618's at USC, whose computer labs charged me $2 a square foot. (I often printed extra rectangles with just our number, just in case.)
Before/After:
2009
For 2009, we went with an all-black look--and about hit it. In spite of many last-minute scrambles right before ship, we were largely successful with a few other tricks:
Spray paint. The only part of the robot we were able to spray paint were the side and rear plywood panels around the lower part (and even then, only on one side). A few coats gave it a nice look from the stands.
Gaffer's tape. With the aluminum superstructure of the robot in the crate unpainted, and FIRST rules prohibiting any more painting in the pits, we had to figure out a new way of blacking out the rest of the robot. I was working a fair amount with a cameraman for a local TV station at the time, and he suggested a source for a roll of gaffer's tape. One roll did the entire robot with some to spare, and only ran about $20 after tax. (You might be able to find it cheaper elsewhere.)
Cut vinyl stickers. The last part of the puzzle was getting our schools and sponsors on the robot. Using the company that pinstripes our cars at work, I sent them the sponsors' vector art and had three sets cut for each. Applied properly (place them, tape down one side, flip down, peel off the backing, carefully roll it back up, carefully peel back the top piece), they look great and held up fine even on our painted plywood. Getting all three sets cut (including the differently-colored One Six One Eight) was about $75.
Another before/after:
Unread 29-03-2010, 18:51
pm 2389 pm 2389 is offline
FRC #2389
pm 2389 is an unknown quantity at this point
we use painted aluminum sheet sideing that we etch are sponsors in.
How Do You Give Your Robot It's Signature Look? Pat McCarthy General Forum 29 25-09-2007 21:42
pic: 179 & 1889 Look Good Together Swampdude Extra Discussion 13 31-01-2007 21:37
FIRST 2007 GUIDELINES, TIPS, & GOOD PRACTICES dez250 General Forum 3 09-01-2007 20:26
Good News - Look What We're Doing! KathieK General Forum 5 29-12-2005 13:00
Dean would make a good Donald! Jessica Boucher Televised Robotics 1 13-04-2004 10:42
