Go to Post Well... as ready as we can be 30 days before build season... We definitely do not have a robot yet though... :) - pandamonium [more]
Unread 29-03-2010, 13:31
foote stepped in
AKA: E. Foote
FRC #0868
Re: How Do mecanum wheels handle the bumps?
I claim the following happens:
- Up to a certain point, both robots push with exactly the same force. There is no 71% factor involved.
- If the motors are sufficiently powerful, a point will be reached where the wheels start to slip. RobotA, with the mecanum wheels, will reach this point before RobotB, with the standard wheels.
Consider a wheel with rollers free to spin on the same axis as the main axle. It doesn't matter how grippy the material is for the rollers, these wheels can't apply a force no matter how hard they drive or how fast they spin.
Consider a wheel with rollers free to spin on an axis perpendicular to the main axle (traditional trick/omni wheels). It doesn't matter how hard they drive, they'll have the same coefficient of friction as wheels without the roller but made with the same material.
Mecanum wheels are in the middle - they spin on a 45.
If you take a mecanum wheel and spin it, you'll find that it pushes you on a 45. Its hard to describe the feel until you actually do it.
No matter which way the wheels spin, they're fighting each other.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It. Like our values? Flexware Innovation is hiring!. We're looking for Senior Automation, Software, and System Engineers. Check us out!
How to mount mecanum wheels Sam2197 Technical Discussion 6 16-12-2008 18:32
pic: Figuring out the mecanum wheels Rapt0r9 Extra Discussion 4 25-01-2008 19:55
Mecanum Wheels is it good fin the Pits yara92 Technical Discussion 18 21-12-2007 00:14
How Do Mecanum Wheels Work? SPARKY1688 Kit & Additional Hardware 9 08-01-2007 23:39
Split topic - How many channels can the current (2004) Oi's and Rc's Handle? Elgin Clock Control System 6 02-01-2005 14:02
