Go to Post My contention is that there is not a whit of difference between noting that a change like that has to be made, and making the change. - Kris Verdeyen [more]
Unread 29-03-2010, 17:15
Damaku250's Avatar
Damaku250 Damaku250 is offline
Electromechaneumatics guy
AKA: Craig Hoo
FRC #3161 (H.T. Tronic Titans)
Team Role: Electrical
Damaku250 is an unknown quantity at this point
Spontaneous motor skipping?
We appear to be having an odd problem with our drive motors.
Following an odd voltage drop resulting in the loss of control of our bot in the quarter-finals at WAT, we had discovered that one CIM and its accompanying Jag were noticeably hotter than the others.
After removing the electronics and offending gearbox, getting home and testing them on benchtop, we've noticed two things:
1) after removing our CIMs from the gearbox the one that was overheating is also making an odd clicking and is noticeably louder than the other. [Resolved]
2) that our CIMs "jump" and will randomly stop for a random duration between 1/4 and 1/2 a second. When this happens, all the motors jump simultaneously, and the lights on all the Jaguars flash yellow/amber for a brief period while the motors stall.
We HAVE tried changing the DSC and 9403 cRIO modules, to no avail.
-Rookie All Star Award [WAT Regional 2010]
Electrical/Control systems, Mechanical and Pneumatics teams, Human player
Unread 29-03-2010, 17:23
Re: Spontaneous motor skipping?
Craig,
Sounds like you have a shorted winding in the CIM motor. No way to fix that, just replace.
Unread 29-03-2010, 17:24
Damaku250's Avatar
AKA: Craig Hoo
Craig,
duly noted, but would this cause the second part of the problem?
Unread 29-03-2010, 17:26
Yes, you are drawing down the 12 volt supply which draws down the DSC power that in turn plays havoc with the PWM outputs.
Unread 29-03-2010, 17:28
Damaku250's Avatar
AKA: Craig Hoo
We have now removed the borked motor and are testing with the good one. We are still experiencing "skipping". What could be causing this?
Unread 29-03-2010, 17:30
Craig,
Is the robot signal light also blinking out at the same time?
Unread 29-03-2010, 17:34
Damaku250's Avatar
AKA: Craig Hoo
Craig,
No, the RSL is staying on and we do not appear to be experiencing power interruptions on any other components on the board.
Unread 29-03-2010, 17:46
You are using the same Jaguar? Suspect that as well.
Are any of the lights on the PD winking out at the same time?
Unread 29-03-2010, 17:49
Damaku250's Avatar
AKA: Craig Hoo
We have tried the motor with all 4 different jaguars mounted on our board. All jaguars experience an interruption at the same time.
The lights on the PDB are staying solid.
We have tried 5 different versions of code, all of which are not affecting the problem.
Unread 29-03-2010, 17:54
Craig,
Is this a new problem? Have you had this all season or just recently? It is possible that you have the dreaded watchdog issue. Someone posted last night that there is an issue with Classmate power settings as well. I believe the Classmate issue occurs at 15-20 second intervals while the watchdog is something longer.
Unread 29-03-2010, 17:55
AKA: Dr. Brooks
no team (WRRF)
Watch the little screen on the lower left of the
driver station display. Do you see a momentary
"watchdog not fed" message correlated with
the motor glitches? If you see it, you have the
dreaded watchdog issue Al mentions.
Eugene
Unread 29-03-2010, 18:01
Azores's Avatar
Azores Azores is offline
AKA: Andrew
FRC #3161 (Tronic Titans)
Azores has a spectacular aura aboutAzores has a spectacular aura aboutAzores has a spectacular aura about
It is definitely not a 15-20 second cycle, we've had the CIM running for up to 1:30 before it skips before. It may be a Watchdog issue - I'll go run another test and keep an eye out for the Watchdog issue.
This is, as far as we know, a completely new issue however. We hadn't noticed this motor skipping problem for all of build season or all of the practice and seeding matches at Waterloo.
Unread 29-03-2010, 18:08
Azores's Avatar
AKA: Andrew
Just ran the test. Watchdog is indeed cutting out...
Unread 29-03-2010, 18:29
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Yes we had exactly the same symptoms early in our build season. At first it was manifested in a compressor that wouldn't go up to 120psi, then we noticed the intermittent Watchdog Not Fed error. It also caused the motors to hitch and jerk when they should just be running. We widened the setpoint for the watch dog to .4 seconds and made sure every bracketed piece of code feeds the dog and haven't had an issue since.
I don't need a signature.
Unread 29-03-2010, 18:42
Azores's Avatar
AKA: Andrew
Widened the setpoint? I'm not sure what you mean by this. A delay before first feeding it?
[Vex] Spontaneous channel switching/dying Joe G. VEX 2 15-04-2009 16:17
Motor speed sensing with the Jaguar motor controller? mminutto FRC Control System 5 13-01-2009 18:13
White Paper Discuss: Approx. Motor Spec for Taigene Motor Joe Johnson Motors 2 22-01-2005 16:36
External metal jacket on the Drill motor and FP motor, WHY? archiver 2001 3 24-06-2002 04:22
External metal jacket on the Drill motor and FP motor, WHY? Dennis Hughes Technical Discussion 1 04-06-2001 11:59
