Re: Best 2010 Autonomous
How repeatable is this? Our issue is that while the balls usually land in about the same spot, they end up with variable amounts of spin and bounce which sometimes make them ricochet off the chains or hit the metal bar on the top of the goal. This problem seems to be pretty ubiquitous among teams. If 67 is consistently scoring 3-4, I'd love to see how they coped with this issue.
My team, (1592) shoots 5 balls in autonomous consistently. The 3 in the far zone, and the 2 in the middle. Last week at Colorado, we made 4 in during one of the qualifications. Others, making usually 2-3 balls in.
I think the issues you mentioned are affecting all teams out there, and can keep anyone from scoring a perfect auton mode from zone 3 every time. |
Check out the first match of the Finals in LA this last weekend. 9 points scored in autonomous
http://www.thebluealliance.net/tbatv/match/2010ca_f1m1 |
Best auton thus far:
2851 making what is believed to be the first "469 auton". We successfully wedged ourselves in the tunnel and our treaded wheels kept us there. |
#7
Scoring 2 or more points in autonomous is probably one of the most advantageous. 2016, 1519, and 230 won events partly because of autonomous, so I'll go with them simply due to their higher than average repeatability.
#8
1772 definately had the best autonomus at palmetto, but from reading these posts it sounds like it was nothing compared to a lot of teams.
#9
He also lent his code to many other teams at Troy to use ![]() Quote:
I can agree with the chain issues; it seems that they are the reason a team doesn't score all of their balls in auto (us included!). And it's definitely more important to get the balls into your zone. Sure, a few points are nice, but with the balls in your zone it allows for two things: 1. Your balls are out of your opponent's home zone 2. The balls are in your home zone, so you can easily score them. Last edited by Alex Dinsmoor : 29-03-2010 at 20:52. |
#10
1261, 343, and 2815 made 4 in finals at Palmetto.
We(1261) would consistently make 1, and 2815 would consistently make one. The points went between 2-4 depending on how our shots/343's shots went. But regardless, the autonomous buffer was still extremely comforting when entering teleop. |
#11
We have ours set up for 2 different sets, our slow setting(3-ball) kicks only the far 3, our Fast setting(5-ball) kicks the far three and middle 2
our slow setting scores 1 everytime, 2 50% of the time and we have scored 3 in a couple matches our fast setting kicks all 5 85% of the time and always scores 1-2, scores 3 about 30% of the time and we scored 4 balls in 1 match and the 5th ball was kicked into the front zone (all these scores are from our robot alone, not counting our other alliances number scored) Last edited by dodar : 29-03-2010 at 21:00. |
#12
1502, the MeTool brigade, was able to score 2-3 balls consistently from the far end. They ended up winning the St Louis Regional.
#14
The MeTool Brigade is team 1208.
#15
| Best 2010 Rookie Team | Dan 1038 | Regional Competitions | 30 | 27-04-2010 16:45 |
| Best 2010 Lifter | TheFish | General Forum | 56 | 12-03-2010 17:23 |
| Best 2010 Kicker | TheFish | General Forum | 3 | 08-03-2010 10:11 |
| Best of autonomous modes | Bryan Herbst | Programming | 8 | 28-03-2008 23:33 |
| Best Autonomous | BornaE | Programming | 46 | 15-05-2007 17:59 |
