Go to Post REAL WORLD = TOP PERFORMANCE... otherwise, get used to Ramen Noodles dinner or living in your childhood bedroom. - Michael Blake [more]
Go Back   Chief Delphi > Competition > Championship Event
Unread 29-03-2010, 17:25
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Robot Communications at the Championship
I'm sure FIRST has got this covered, I'm just interested so I thought maybe someone could shed some light on this subject:
with 4 fields running simultaneously fairly close to each other, is it necessary to set up the communication in a special way to avoid communication problems? if so what do you imagine (or know) this configuration to be?
would a WiFi expert look at this setup (24 robots running simultaneously on 24 different networks) and see a potential problem, or would he shrug it off as a non-issue?
I'd appreciate to learn more about the advantages and limitations of the 802.11n protocol and the configuration used.
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 29-03-2010, 17:36
Racer26 Racer26 is offline
Re: Robot Communications at the Championship
Not having been there, I can't say for sure, but I believe CMP runs the fields one at a time, running one while the others are resetting. Also, in my experience 802.11 is fairly forgiving of multiple networks sharing channels in close proximity.
Unread 29-03-2010, 17:39
Nope, it's 4 fields simultaneously. Or pretty darn close, depending on match schedule and how far ahead or behind each field is schedulewise.
Robot Communications dies as Motor speed increase Michael Fadaie NI LabVIEW 4 19-02-2010 00:55
No Robot Communications alex42 FRC Control System 4 10-02-2010 20:42
No Robot Communications Team2191 FRC Control System 1 22-01-2010 20:12
[FVC]: Transporting your robot to the Championship nonother FIRST Tech Challenge 14 31-03-2007 01:40
Communications via the Programming Port Larry Barello Technical Discussion 9 10-06-2003 23:33
