Go to Post Sometimes, having someone that can teach you just shows you another way to do what you've been doing, but in fewer moves. - Amanda Morrison [more]
Unread 29-03-2010, 21:39
whatabouteve whatabouteve is offline
AKA: Dean Keithly
FRC #0245 (Adambots)
whatabouteve is an unknown quantity at this point
Re: Camera other than Axis 206?
i got it set up exactly like it says in the manual, set comp ip to 192.168.0.6 go to web browser and got to 192.168.0.90 then set password and configure to 340 x 280 or whatever that size was.
It was done exactly the way FIRST says to do it and when we plug it in with the old code that worked with the 206 camera, bam the cRio does what i previously explained.
Eceryone i have talked to at other competitions said "we just configured it and plugged it in" except for 70's programmer, he did some crazy stuff with the libraries that i don't intend to do since i only want an image.
Axis 206 Camera Power Supply EricWilliams FRC Control System 1 02-02-2010 17:18
Axis Camera 206 Power Connection Matt2081 Electrical 7 24-01-2010 15:51
About the 206 Axis Camera yoavh360 Electrical 8 18-01-2010 15:14
Programing servo in Axis camera 206 frcchile NI LabVIEW 6 18-01-2009 08:53
