Go to Post Diversity means diversity in ideas too. Some of the robots from the singapore competition might have employed strategies or ideas that we may not even have come up with in North America. - J Flex 188 [more]
Unread 29-03-2010, 22:41
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: Camera other than Axis 206?
Originally Posted by whatabouteve View Post
i got it set up exactly like it says in the manual, set comp ip to 192.168.0.6 go to web browser and got to 192.168.0.90 then set password and configure to 340 x 280 or whatever that size was..
I am not particularly versant with the IP configurations of the new controls system, but I know most things are 192.xx.yy.1, rather than 192.168.0.1. Are you sure the middle of the IP doesn't need to be your team number?
Unread 29-03-2010, 23:31
Pausert Pausert is offline
FRC #1727 (REX)
Pausert is an unknown quantity at this point
The camera does not follow the typical FRC naming convention, which 10.xx.yy.z where xxyy is the team number and z is the identifier for the router, bridge, cRIO, Classmate etc. The default IP is correct on the older camera, but I don't know about the new, square one.
Unread 30-03-2010, 07:37
whatabouteve whatabouteve is offline
AKA: Dean Keithly
FRC #0245 (Adambots)
whatabouteve is an unknown quantity at this point
It says it is the same ip address. My question is involving how the actual camera functions and the code works with the data because my big theory is,
The camera sends more information to the cRio than the cRio actually dumps out of its system. That is why after 6 seconds of being turned on and operating fine, the cRio has overflow errors because it is trying to hold onto too much data.
I need a way to change the subroutine called upon by
AxisCamera &camera = AxisCamera::GetInstance();
Since it is the only thing that seems wrong with the entire setup because
i recieve the proper image i ask for and it runs on the cRio.
Unread 30-03-2010, 08:41
The cRIO and camera both have 100Mbit ethernet. The new and old camera both compress images using the same algorithm. The new one is or seems to be largely compatible with the old one. Provided you put an account on the camera, it should respond with images, just like the 206 did.
The GetInstance() function opens the TCP session with the camera. It is hanging, returning an error, or what?
Greg McKaskle
Unread 30-03-2010, 10:35
The camera is on the second network port of the cRIO. It is indeed supposed to be at the 192.168.0.90 IP address.
Unread 30-03-2010, 15:23
AKA: Dean Keithly
Here is an exact description of what happens:
we power up the cRio
the netbook connects to the cRio
the camera turns green
we enable the cRio
the robot begins sending an image once teleoperated starts
(This is because we have the single line of code just before the teleoperated loop)
watchdog might flicker on the screen for a moment
after between 6 to 7 seconds, Watchdog appears, stays, and the robot loses connection. It remains that way until we physically turn off the robot.
that is all that happens every time.
Unread 08-04-2010, 13:15
thetallmage thetallmage is offline
thetallmage is an unknown quantity at this point
Question Re: Camera other than Axis 206?
Question. Are there any hardware differences to the newer model that makes it mount to the "pan and tilt assembly" differently or is this not a concern?
Unread 08-04-2010, 13:27
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
We don't use the Pan and tilt system but here are some pictures of the two cameras.
Axis 206 Camera Power Supply EricWilliams FRC Control System 1 02-02-2010 17:18
Axis Camera 206 Power Connection Matt2081 Electrical 7 24-01-2010 15:51
About the 206 Axis Camera yoavh360 Electrical 8 18-01-2010 15:14
Programing servo in Axis camera 206 frcchile NI LabVIEW 6 18-01-2009 08:53
