Go to Post I may be a little slow responding, I'm shoveling snow. - Mark McLeod [more]
Unread 30-03-2010, 10:21
SteveD SteveD is offline
FRC #0888
SteveD is an unknown quantity at this point
Re: Crio Problem
Check your pwm system for shorts. If any of the pwms are shorting between the hot and ground, the 5 volt current will be diminished, and will not work. Check all inputs and outputs.
Hope this helps
cRIO output problem alex42 FRC Control System 1 27-01-2010 22:28
cRio problem specs101kid Programming 4 21-01-2010 16:19
cRIO communications problem alex42 FRC Control System 5 16-01-2010 20:22
cRIO Problem Pneumaticsman NI LabVIEW 8 10-01-2009 11:59
cRIO plugin problem gabrielse National Instruments LabVIEW and Data Acquisition 3 18-12-2008 11:30
