Go to Post Look around. What else could cause folks to go sleepless for six straight weeks? That's life-changing, isn't it? :D - Billfred [more]
Unread 22-02-2010, 18:18
frcchile's Avatar
frcchile frcchile is offline
FRC #2576
frcchile will become famous soon enough
Crio Problem
Hey my friends:
Two days ago our robot was working very good, yesterday I can't move sensors, camera, encoder.But only the motor can work I dont know why, is the same program, the same conextion, I changed the wires conexion but the problem is the same I am thinking if is the problem with Crio so I want to Know if could be this problem, What happens if I reset the Crio??? the problem is common???
Thank you!!
PD: What update I need for restart the Crio??
Unread 10-03-2010, 15:52
randalcr's Avatar
randalcr randalcr is offline
Programming Mentor
AKA: Chance Randall
FRC #0476 (Wildcats)
randalcr is an unknown quantity at this point
Smile Re: Crio Problem
All the updates you need are on usfirst.org, if yo haven't updated he CRIo image then that might be a part of your problem. You might also check to make sure your crio and camera are electrially isolated fom your frame, we had a CRio blow a fuse b/c it wasnt isolated. And resetig the crio basically rboots it.
Hope this helps, and sorry for the mistakes... Typing on an iPod touch is not easy!
Unread 30-03-2010, 10:21
SteveD SteveD is offline
FRC #0888
SteveD is an unknown quantity at this point
Re: Crio Problem
Check your pwm system for shorts. If any of the pwms are shorting between the hot and ground, the 5 volt current will be diminished, and will not work. Check all inputs and outputs.
Hope this helps
cRIO output problem alex42 FRC Control System 1 27-01-2010 22:28
cRio problem specs101kid Programming 4 21-01-2010 16:19
cRIO communications problem alex42 FRC Control System 5 16-01-2010 20:22
cRIO Problem Pneumaticsman NI LabVIEW 8 10-01-2009 11:59
cRIO plugin problem gabrielse National Instruments LabVIEW and Data Acquisition 3 18-12-2008 11:30
