Re: pic: The lights! The lights!
Nice!
I like the functionality that was attached to the lights so they serve more than one purpose. Out of curiosity, where'd ya'll get them and/or hook them up? -Tanner |
The lights were purchased from a local company http://www.lighthouseww.com/index.ph...index&cPath=81. A bit expensive but extremely bright. If you buy from them mention our team it might increase my discount.
Do you have 2 strips of lights there or just 1 strip of the color changing ones? Also curious how you hooked them up to allow you to change color as well as flash them with the pneumatics? I'm assuming that there current draw was too great to just put right off one of the break out boards.
There are two strips of lights, red and blue. Each strip is driven by a spike relay module. We have a Hobbs digital pressure switch set at 60 PSI on the pneumatics. The robot will flash the lights until that pressure is read by turning the relay on and off. The pressure switch was in the 1999 or 2000 kit of parts. Most of our robot is made of recycled parts including the lights that we used last year.
We have six 12" lights on our robot, connected to 3 Spike channels (2 spikes), in Red, Green, and Blue. No RGB color, just Red, Green, or Blue (or more than one). We use Blue to indicate ball in and Green to indicate High Gear (much easier for the coach to yell at the driver for running around in LOW). When the robot hangs from the vertical pole, they flash in sequence as soon as it is above the platform. |
#7
| Are Lights Allowed on the Robot?? | team 2191 | Electrical | 5 | 14-02-2008 18:00 |
| The chasing-lights RC error | Eldarion | Control System | 7 | 25-01-2006 18:23 |
| One of the RC lights is out | devicenull | Control System | 1 | 13-02-2005 22:41 |
| Lights on the Control Panel | Han Tzu | Electrical | 5 | 08-02-2005 13:30 |
| Rotating Lights in the stands? | psychoCHIPMUNKK | Rules/Strategy | 4 | 19-02-2004 23:47 |
