Go to Post Gracious professionalism is a two-way street. - Bharat Nain [more]
Unread 30-03-2010, 19:15
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Re: New Black Jaguars?
Originally Posted by sashboy226 View Post
We use them the same way as we would use the tan jags.
And apparently they didnt break, we got metal shavings in them. We cleaned them out and they should work fine now. One powers up fine, but we havent tested the actual motor control yet.
As I stated above, the black Jags are not the same as grey Jags. If you use the CAN bus, you use a black Jag to connect to the cRIO via the RS232 serial line. (You can avoid the black Jag by using a 2CAN adapter between the cRIO ethernet port and a grey jag).
Metal shavings can spell death to robot speed controllers (Victors or Jaguars). Avoid drilling, grinding, filing on your robot with the electronics unprotected. It's really painful when you blow-up a speed controller just before a match. I know.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
CAN Bus Control via Black Jaguars -- SOLVED!! taichichuan C/C++ 6 15-02-2010 15:11
Black Jaguar Not Taking New Address duane CAN 1 06-02-2010 19:55
Black jaguars: not working ellisk C/C++ 55 02-02-2010 11:14
Serial to CAN Gateway in new Black Jaguars? dmcguire3006 Electrical 54 26-01-2010 07:32
New Jaguars on CAN bus ellisk C/C++ 4 21-01-2010 09:53
