Go to Post It is one thing to be a great designer, it is another thing to be able to explain what you did, how things work, and why things happen. - Andy Baker [more]
  #41   Spotlight this post!
Unread 30-03-2010, 19:47
hektormagee's Avatar
hektormagee hektormagee is offline
AKA: Jeff
FRC #2137 (T.O.R.C.)
Team Role: Human Player
hektormagee will become famous soon enoughhektormagee will become famous soon enough
Send a message via AIM to hektormagee
Re: The ultimate game breaker bot.
Originally Posted by pbhead View Post
I may have found something that may be too good to be true... but i have not found anything in the rules that would make it illegal.
Immagine a robot... it cant go over the bump... it cant go under. It starts in the middle zone. in autonomous it uses a very basic pnumatic kicker to get those 2 balls just over to its home field... no aiming into the goals... just getting the balls to the right side of the field. very basic.
As soon as tellop starts, it goes in front of its tower, it touches the tower, and then deploys 2 gravity powered guides that physically attach the robot to the sides of the tower, and keep it level. then, using a very basic winch-and hook, it begins climbing. It reaches the top. the top of this robot is shaped in such a manor that the balls that fall off the ball return hit the top of this robot, and the balls are redirected straight back into the goal... a simple servo connected to a bar directs the balls either to the left goal or the right goal.
basicly, a bot that all it does, is that as soon as a goal is scored, it returns the balls straight back into the goal... every one of the 12 balls the other 2 robots place into the goal means that as soon as that ball is placed back on the ball return, 5 seconds later its right back in the goal. if a robot trys to block the goal... this "god bot" simply directs its payload towards the opposite goal. and as an added bonus, you got a minimum of 2 points for hanging.
any thoughts about this?
the only thing that perhaps could be questionable would be the server that redirects the balls to the right goal or left goal... but there are many ways... to use a properly designed lifting mechanism to till the frame one way, and the balls go left, till the frame the other way the ball goes right.
469 does exactly this, minus the hanging.
Anyone up for a little game of ultimate frisbee? #2970-Dan Championship Event 17 13-04-2009 10:31
FIRST Game Survivor: Tie-Breaker Justin Montois Games/Trivia 0 19-03-2009 13:20
pic: Nah, We just have a set for the Alpha bot and the beta Bot Kevin Ray Extra Discussion 10 25-01-2009 18:40
pic: Ultimate 4 Square Field (Vex Game) Alex Cormier Extra Discussion 11 04-07-2007 14:12
The Ultimate Showdown of Ultimate FIRSTiny Billfred Chit-Chat 4 12-04-2006 22:43
