Go to Post Its a good bug too. :) - spadercool [more]
Thread Tools Rating: Thread Rating: 3 votes, 3.67 average. Display Modes
Unread 30-03-2010, 21:59
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Programmers: I Have A Challenge For You
Originally Posted by davidthefat View Post
All of you who are attempting this, how do you suppose you will get started? I am thinking of making an omni drove robot with 2 gyros, one in the main body and one on a little platform that a server will rotate up and down. 2 IR sensors mounted on a servo that will rotate it side to side will scan in front of the robot and the other 2 mounted on the platform will also scan side to side. they will take in an array of data regarding the objects inthe way
I'm curious. Are you aware that a single hard collision can easily throw a gyro off by hundreds of degrees?
We removed our gyro from this year's competition bot - we were using it to measure inclination in order to automatically stop our winch - because each time we fired our kicker (it was a 300+ degree per second gyro) it would lose 30-40 degrees in a random direction. In fact, we tried 6 different gyros, all the ones we had in the build room, and they all showed the same results.
We used one in 2009 to make our turret field-oriented and had the same issue when we had a hard collision.
I'm also curious why you want a gyro on a platform when servos can be commanded accurately to any angle you want?
For those of you that have seen a field goldenglove002 General Forum 1 13-02-2010 21:56
SE MI Teams - I have pool noodles for you! kmcclary General Forum 1 05-02-2010 20:29
Any Programmers Have The Same Feeling As Me? davidthefat Programming 23 16-01-2010 22:07
What have you given up for FIRST? Michael Leicht General Forum 138 11-01-2008 10:47
