Go to Post And then the judges joined in and did the wave! - Basel A [more]
  #151   Spotlight this post!
Unread 30-03-2010, 19:47
hektormagee's Avatar
Happy Birthday! hektormagee hektormagee is offline
AKA: Jeff
FRC #2137 (T.O.R.C.)
Team Role: Human Player
hektormagee will become famous soon enoughhektormagee will become famous soon enough
Send a message via AIM to hektormagee
Re: The ultimate game breaker bot.
Originally Posted by pbhead View Post
I may have found something that may be too good to be true... but i have not found anything in the rules that would make it illegal.
Immagine a robot... it cant go over the bump... it cant go under. It starts in the middle zone. in autonomous it uses a very basic pnumatic kicker to get those 2 balls just over to its home field... no aiming into the goals... just getting the balls to the right side of the field. very basic.
As soon as tellop starts, it goes in front of its tower, it touches the tower, and then deploys 2 gravity powered guides that physically attach the robot to the sides of the tower, and keep it level. then, using a very basic winch-and hook, it begins climbing. It reaches the top. the top of this robot is shaped in such a manor that the balls that fall off the ball return hit the top of this robot, and the balls are redirected straight back into the goal... a simple servo connected to a bar directs the balls either to the left goal or the right goal.
basicly, a bot that all it does, is that as soon as a goal is scored, it returns the balls straight back into the goal... every one of the 12 balls the other 2 robots place into the goal means that as soon as that ball is placed back on the ball return, 5 seconds later its right back in the goal. if a robot trys to block the goal... this "god bot" simply directs its payload towards the opposite goal. and as an added bonus, you got a minimum of 2 points for hanging.
any thoughts about this?
the only thing that perhaps could be questionable would be the server that redirects the balls to the right goal or left goal... but there are many ways... to use a properly designed lifting mechanism to till the frame one way, and the balls go left, till the frame the other way the ball goes right.
469 does exactly this, minus the hanging.
  #152   Spotlight this post!
Unread 30-03-2010, 21:21
Originally Posted by bobrenjc93 View Post
Eh? When you say "locking", do you mean an actual locking mechanism, or just the locking produced by the friction force? From the videos I've watched, it looks as if all 469 does is drive under the tower and raise their arm.
They also raise a piece inside the tunnel. This wedges the robot firmly in place. It braces against the pipe across the tunnel entrance.
Short of literally breaking the tower, nobody is pushing that robot out of there.
  #153   Spotlight this post!
Unread 30-03-2010, 23:50
eyu100 eyu100 is offline
eyu100 has a spectacular aura abouteyu100 has a spectacular aura about
Well, breaking their mechanism would also do it...
  #154   Spotlight this post!
Unread 31-03-2010, 08:36
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Look at the date of his post (01-14-2010, 08:27 PM). A month and a half before the 1st regional and a week after kickoff
Long before 469 built their robot.
___________________
- Tennyson, Ulysses
  #155   Spotlight this post!
Unread 31-03-2010, 09:14
MCahoon MCahoon is offline
FRC #3826 (Sequim Robotics Federation)
MCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud of
Thumbs up Re: The ultimate game breaker bot.
Originally Posted by 1075guy View Post
seems to me that you could probably get the deflector configured in such a way that the energy of the ball coming down the return is enough to push it forward and hit the angled part of the hump, which, if positioned right, could give it the required energy to go directly into the goal. now sure, a defensive bot could try to get in the way, but if you're able to change the direction the ball goes, then what can they do? the ball is smaller and faster than a 120lb robot.
Post #46 on 1-15. 469's design seems to implement virtually every significant feature as discussed in the two threads which addressed this idea, with the addition of driving under the platform rather than hanging, which allows them to disengage and play (though at the cost of the 2 hanging points). Major props to their designers.
  #156   Spotlight this post!
Unread 31-03-2010, 09:46
Racer26 Racer26 is offline
I certainly thought it was possible and within the rules to do it. 469 did. Kudos.
  #157   Spotlight this post!
Unread 31-03-2010, 10:01
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Or climbing on them.
Anyone up for a little game of ultimate frisbee? #2970-Dan Championship Event 17 13-04-2009 10:31
FIRST Game Survivor: Tie-Breaker Justin Montois Games/Trivia 0 19-03-2009 13:20
pic: Nah, We just have a set for the Alpha bot and the beta Bot Kevin Ray Extra Discussion 10 25-01-2009 18:40
pic: Ultimate 4 Square Field (Vex Game) Alex Cormier Extra Discussion 11 04-07-2007 14:12
The Ultimate Showdown of Ultimate FIRSTiny Billfred Chit-Chat 4 12-04-2006 22:43
