Go to Post Snow Blower Motor? Forget the water game, how about a snow game? - Gary Dillard [more]
  #31   Spotlight this post!
Unread 30-03-2010, 19:07
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: Penalties for a part falling off of robot?
Originally Posted by David Brinza View Post
I don't believe the GDC intended <G41> or <R16> to apply to cases where mechanical or structural failures have occurred in robots. (We'll need to see the answer in FIRST Q&A to get this resolved).
Don't forget G30. We got called on that once (lost us the semis too), and we got a warning about it once or twice (unrelated issue). If any part of the robot, including decorative panels breaks the frame perimeter illegally, I promise you that it is most definitely counted
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
  #32   Spotlight this post!
Unread 30-03-2010, 19:10
kirtar kirtar is offline
Alumnus
kirtar will become famous soon enough
Honestly, it's not easy to make an absolute statement about this. As an example, if you drop a single bolt or a nut, I don't know that it should be called. However, if for example (with something that happened to us at Buckeye), the cover of your robot comes off completely or partially, you should at least get a penalty for extending beyond standard configuration. Of course, in the above mentioned case, it also made it so that we weren't elevated because it hung down a lot.
  #33   Spotlight this post!
Unread 30-03-2010, 19:23
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
My thoughts about penalties (which might be different than the referees or GDC) revolve around whether an alliance is gaining an advantage by virtue of the infraction.
If your robot extends beyond the frame perimeter and you are able to block shots or prevent an opponent from maneuvering past you - penalty!
If your robot is damaged, breaks off a wheel and can only drive in circles - no penalty!
If an opponent's robot impacts your robot and causes a part to come off, should this be a penalty? If so, WHO should be penalized?
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
  #34   Spotlight this post!
Unread 30-03-2010, 19:38
Zultraranger Zultraranger is offline
FRC #0870
Zultraranger will become famous soon enoughZultraranger will become famous soon enough
Long Island SBPLI Regional did not enforce that rule. They kept it consistent throughout the competition, robots would lose parts and they were not penalized.
  #35   Spotlight this post!
Unread 30-03-2010, 19:54
Rick Wagner's Avatar
Rick Wagner Rick Wagner is offline
FRC #3008 (Kalani Robotics)
Rick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to behold
A referee at LA explained it this way to me: if a part falls completely off a robot, there is no penalty. If a part (like a chain) is dragging outside the frame perimiter, penalty. That makes sense to me.
One team (to remain unnamed) had a bumper fall completely off three times in three different matches and got three penalties for it. The rule in this case is that robots must have bumpers all around.
  #36   Spotlight this post!
Unread 30-03-2010, 20:17
I believe the BeachBots were penalized in the last finals match after they lost a chain - it was lying on the field, away from their robot. From what I heard, there was a lack of consistency in the calls at LA. Apparently, there isn't consistent interpretation across all of the events.
  #37   Spotlight this post!
Unread 30-03-2010, 20:21
The way I understood the explanation from the referee, if the chain was dragging outside the frame perimeter before it fell completely off, that would be a penalty.
  #38   Spotlight this post!
Unread 30-03-2010, 20:40
Perhaps...but what an "interesting" interpretation of the rules by the referees.
What advantage is gained by dragging a part around the field that should be working in a drive system or manipulator? I don't recall penalties being issued in prior years for having a robot component come off of the robot (unless it was a safety issue). Usually, such failures create such a significant disadvantage for the alliance that adding a penalty would seem unwarranted (or even mean)!
  #39   Spotlight this post!
Unread 30-03-2010, 21:59
Sumathi's Avatar
Sumathi Sumathi is offline
FRC #2410 (The Metal Mustangs)
Sumathi is an unknown quantity at this point
I believe it is normal to see this now. We lost points during the final matches because our bumpers were falling off. (frame was broken) At first I began to question why they would penalize us when it was the other robots fault for agressive driving. I finally reasoned what I think FIRST wants us to play by. There was a part in the rules saying that there would be lots of contact so be prepared, therefore we should have been prepared. Because our robot broke down we were not prepared and therefore should be penalized for the broken parts falling out side of the perimeter.
Disclaimer: This is the way I understand it, if you don't agree feel free to elaborate or offer a different view.
  #40   Spotlight this post!
Unread 31-03-2010, 01:20
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
Strange, I never remember it being this way. Especially back when we didn't have bumpers .
The GDC needs to fix this; it is pretty inevitable, unless your robot is one solid block of aluminum. It should be a judgement call, but I think it should be a much more lenient one. Thrown chain/ Lost Wheel? No penalty. Heavy opponent contact? No penalty. Unable to withstand basic rigorous motion? Penalty.
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
  #41   Spotlight this post!
Unread 12-04-2010, 15:18
Given the inconsistency of penalty calls for loss of robot parts in various regionals, I posted a question in Q&A Section 7. If loss of robot part on the field is deemed a penalty, I asked whether it is still a penalty if the robot was damaged by impact from another robot.
Was there a response to this question? I looked and couldn't find it. It seems at this point that the drivers meeting would be the only way to get an answer.
  #42   Spotlight this post!
Unread 12-04-2010, 15:29
I did post the question to Q&A on 3/29 and have yet to see a response. Someone should bring this up in the Driver's Meeting.
World record for penalties in one game Yoel2630 Robot Showcase 15 23-03-2010 16:04
Falling Robot Perimeter regiquest Rules/Strategy 3 03-02-2010 17:50
Appropriate penalties for off-the-field ethical/behavioral violations Steve W General Forum 65 08-01-2005 00:17
Falling off the bar... :\ Swampmonkey General Forum 47 14-03-2004 12:47
Falling Robot Mullen Technical Discussion 1 16-01-2003 16:38
