Go to Post Wow, my dad's sadistic nature is rubbing off on me. - Lil' Lavery [more]
View Poll Results: Was this useful?
Yes, it was! It helped point out diamonds in the rough 109 70.32%
No, its numbers generally did not correspond to robot's actual on-field performance 46 29.68%
Voters: 155. You may not vote on this poll
Thread Tools Rating: Thread Rating: 32 votes, 4.88 average. Display Modes
  #166   Spotlight this post!
Unread 24-03-2010, 06:23
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: Easy to use Offensive Power Rankings (OPR) program for mid-regional scouting
I knew there was something else I had to update last night.
v13 - Now includes new-or-renamed-regionals for 2010.
  #167   Spotlight this post!
Unread 24-03-2010, 09:10
Nawaid Ladak's Avatar
Nawaid Ladak Nawaid Ladak is offline
The Banana People Are Awsome!
AKA: Nawaid Ladak
FRC #0945 (Team Banana)
Team Role: Tactician
Nawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant future
Send a message via AIM to Nawaid Ladak Send a message via MSN to Nawaid Ladak Send a message via Yahoo to Nawaid Ladak
where is the output file? i forgot where OPRNet creates the file.
(Im so used to v11 where teh stats came up in the CommandPrompt window lol)
"When you make a mistake, admit it, correct it, and learn from it - immediately."-Stephen Covey
I can still learn from this quote, how about you?
Nawaid Ladak
2003-2006 FRC # 1402: Freedom Force. Scouting
2007 FRC # 1694: RoboWarriors. Mentor
2008-Present FRC # 945: Team Banana. Mentor
Contact me
E-mail: LadakN (at) GMail (dot) com
Twitter / Facebook / Youtube
  #168   Spotlight this post!
Unread 24-03-2010, 09:28
Bongle's Avatar
It should still come up in the command prompt window. I tested it this morning before I posted, and I just used the prompts. If you launch the EXE without parameters, things should work fine. I haven't tried the command-line parameters yet.
  #169   Spotlight this post!
Unread 30-03-2010, 11:25
cziggy343's Avatar
cziggy343 cziggy343 is offline
cziggy343
AKA: Chris Z
FRC #0343 (Metal-in-Motion)
cziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond repute
Send a message via AIM to cziggy343
has anyone done this for week 4?
Diamond Bullet Studios Co-Founder
http://www.dbsgames.net/index.php
  #170   Spotlight this post!
Unread 30-03-2010, 16:49
Gaurav27's Avatar
Gaurav27 Gaurav27 is offline
Gaurav Bhatt
FRC #1241 (THEORY 6)
Gaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of light
After 4 weeks the following are the top 100 overall entries sorted by OPR:
Net Rank	OPR RANK	Rank @ Regional	REG	Team	OPR	SAA	Net	RPI
1	1	1	oc	469	10.2847	-1.0967	11.3814	0.5841
14	2	1	wat	1114	8.2622	3.4815	4.7808	0.2903
38	3	2	wat	2056	7.6386	3.9768	3.6618	0.2825
2	4	1	pit	1114	6.8567	0.4901	6.3666	0.5508
7	5	1	nj	25	6.4016	1.0638	5.3379	0.5787
15	6	1	mi	1718	6.2664	1.5087	4.7577	0.5745
29	7	1	dt	67	6.0281	1.9127	4.1154	0.5175
8	8	1	sj	971	5.8993	0.5804	5.3190	0.5721
4	9	1	da	148	5.7183	0.0558	5.6625	0.5525
19	10	1	gg	67	5.5703	0.9816	4.5886	0.5825
3	11	2	sj	254	5.5316	-0.1657	5.6973	0.5645
16	12	1	va	1676	5.4403	0.7395	4.7008	0.5687
46	13	2	oc	226	5.4215	2.0165	3.4050	0.5133
10	14	1	ca	330	5.3624	0.1479	5.2145	0.5838
17	15	2	ca	1717	5.2180	0.5195	4.6986	0.5152
5	16	1	roc	217	5.1753	-0.4623	5.6376	0.5003
6	17	1	is	2672	5.1579	-0.3132	5.4711	0.2096
25	18	1	mo	1208	5.0820	0.7504	4.3317	0.5819
36	19	1	fl	1592	5.0322	1.2440	3.7883	0.5859
30	20	1	md	1058	4.9486	0.8944	4.0542	0.5951
9	21	1	il	1732	4.9427	-0.3582	5.3009	0.5953
11	22	1	dt1	217	4.9140	-0.1534	5.0674	0.5621
63	23	2	il	16	4.8138	1.7093	3.1045	0.5472
54	24	3	il	1625	4.8095	1.5339	3.2755	0.5437
23	25	1	oh	3138	4.7388	0.3363	4.4025	0.5208
12	26	1	hi	359	4.6839	-0.2938	4.9777	0.5870
18	27	3	oc	2137	4.6726	0.0476	4.6249	0.5360
954	28	2	is	3065	4.6433	4.8050	-0.1617	0.2567
35	29	4	oc	33	4.5865	0.7873	3.7992	0.5884
119	30	3	is	3076	4.5224	2.1063	2.4161	0.2923
13	31	1	az	330	4.5124	-0.4230	4.9354	0.5375
124	32	1	pa	365	4.4768	2.1363	2.3405	0.5142
95	33	2	gg	910	4.4713	1.8643	2.6071	0.4521
288	34	1	or	997	4.4399	2.9965	1.4434	0.2869
241	35	2	mi	2771	4.3522	2.7459	1.6063	0.4862
83	36	2	pa	272	4.3040	1.5447	2.7593	0.5065
146	37	3	mi	1918	4.2479	2.0754	2.1726	0.5030
108	38	1	in	1501	4.2350	1.7470	2.4880	0.5370
39	39	1	wi	111	4.1591	0.5362	3.6229	0.5150
184	40	1	ma	3280	4.1569	2.3168	1.8401	0.4931
48	41	2	fl	179	4.1372	0.7421	3.3951	0.5616
486	42	3	wat	3396	4.1210	3.3153	0.8056	0.2202
59	43	3	ca	233	4.1149	0.9109	3.2040	0.4926
457	44	2	ma	1511	4.0744	3.1924	0.8819	0.4433
61	45	1	ok	2410	4.0337	0.8529	3.1808	0.5354
376	46	4	wat	610	4.0081	2.8868	1.1213	0.2280
55	47	2	oh	1629	4.0013	0.7342	3.2671	0.5550
535	48	4	is	2669	3.9975	3.3358	0.6617	0.3038
50	49	1	gt	1918	3.9924	0.6474	3.3450	0.4796
26	50	4	ca	294	3.9906	-0.3311	4.3217	0.5157
75	51	2	roc	145	3.9495	1.0688	2.8807	0.4881
53	52	1	ny	341	3.9464	0.6668	3.2795	0.4611
87	53	1	co	1592	3.9352	1.2632	2.6720	0.2042
179	54	2	dt	27	3.9124	2.0404	1.8720	0.5035
60	55	1	kc	1625	3.8903	0.6997	3.1906	0.5204
77	56	3	fl	1065	3.8856	1.0497	2.8359	0.5337
22	57	2	hi	368	3.8634	-0.6368	4.5002	0.6138
32	58	2	da	2016	3.8546	-0.0960	3.9506	0.5386
110	59	5	is	1662	3.8476	1.3739	2.4737	0.1487
67	60	3	gg	2619	3.8276	0.7634	3.0642	0.5244
24	61	1	wa	3221	3.7935	-0.5699	4.3634	0.5922
135	62	2	mo	2775	3.7875	1.5219	2.2656	0.5004
28	63	6	is	1573	3.7864	-0.3303	4.1167	0.2593
44	64	2	wi	2481	3.7814	0.3430	3.4383	0.5784
894	65	7	is	1578	3.7523	3.8000	-0.0477	0.3176
45	66	3	pa	2753	3.7513	0.3162	3.4351	0.5862
127	67	3	oh	1038	3.7445	1.4378	2.3068	0.5520
181	68	2	pit	63	3.7398	1.8879	1.8519	0.5073
27	69	2	in	868	3.7389	-0.4872	4.2261	0.5244
41	70	5	oc	3302	3.7353	0.1603	3.5750	0.5527
33	71	2	az	987	3.7289	-0.2134	3.9423	0.5603
299	72	5	ca	687	3.7206	2.3202	1.4003	0.4560
89	73	3	roc	1551	3.6981	1.0365	2.6616	0.5109
31	74	4	pa	56	3.6765	-0.3144	3.9908	0.5602
42	75	4	il	111	3.6330	0.0705	3.5625	0.5315
64	76	1	li	271	3.6047	0.5002	3.1044	0.5168
62	77	2	kc	2345	3.5996	0.4394	3.1602	0.5632
153	78	5	il	2949	3.5945	1.4820	2.1125	0.5031
244	79	2	va	293	3.5876	1.9855	1.6021	0.4432
102	80	3	in	45	3.5129	0.9644	2.5485	0.4845
66	81	2	nj	303	3.4964	0.4104	3.0860	0.5452
21	82	6	oc	573	3.4959	-1.0076	4.5036	0.5305
58	83	3	kc	234	3.4870	0.2650	3.2220	0.4838
175	84	4	mi	3234	3.4260	1.4888	1.9372	0.5038
132	85	3	mo	1806	3.4018	1.1261	2.2757	0.5221
203	86	3	va	1086	3.3994	1.6153	1.7841	0.4165
20	87	4	fl	103	3.3868	-1.1505	4.5374	0.5637
144	88	5	mi	2645	3.3719	1.1582	2.2137	0.5428
363	89	4	oh	291	3.3446	2.1827	1.1619	0.5155
52	90	2	li	358	3.3433	0.0312	3.3121	0.5549
459	91	2	or	753	3.3422	2.4715	0.8707	0.2321
47	92	8	is	1954	3.3310	-0.0688	3.3998	0.2778
79	93	4	kc	525	3.3070	0.4960	2.8110	0.4974
160	94	4	gg	33	3.3067	1.2528	2.0539	0.5236
445	95	1	nh	78	3.2905	2.3606	0.9300	0.2515
86	96	6	ca	599	3.2855	0.5855	2.6999	0.5066
138	97	2	ok	1939	3.2800	1.0450	2.2351	0.5145
218	98	5	wat	1305	3.2749	1.5839	1.6910	0.2500
72	99	3	da	1421	3.2603	0.3215	2.9388	0.4931
286	100	3	ma	88	3.2464	1.7986	1.4478	0.5018
2016 Newton SubDivision Finalists [254,1731,708]
2016 Waterloo Winners [610,3560]
2016 North Bay Winners [1310,2935]
2013 World Champions [1477,610]
2013 Galileo Division Champions [1477,610]
  #171   Spotlight this post!
Unread 31-03-2010, 01:28
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
awesome! 1592 top 100! just wondering, what is the Net Rank mean? To me it would factor multiple regionals and somehow be averaged together, however there are different Net Ranks for the same team.
also, i'm curious to see how many of these teams either are not going to championships or are currently on the wait list.
unfortunately the Bionic Tigers, the last i heard, still are wait listed.
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
  #172   Spotlight this post!
Unread 31-03-2010, 06:45
Bongle's Avatar
"Net Rank" I think is a bug. If you delete that and shift the rest of the headings over, they all match.
Edit: Nevermind, I just don't know what it is supposed to be.
  #173   Spotlight this post!
Unread 31-03-2010, 10:31
AKA: Nawaid Ladak
by looking at the table, it's pretty easy to see net rank is the ranking of each teams net category.
net = opr-ssa
Nawaid Ladak
Contact me
  #174   Spotlight this post!
Unread 31-03-2010, 11:11
bigbeezy's Avatar
AKA: Bryan
net = opr-ssa
o yeah, duh... thanks that makes sense
  #175   Spotlight this post!
Unread 31-03-2010, 11:43
If you assume 1114 and 2056's poor SAA is because they were scoring for the opponents, it gets even more scary. Both are scoring over 11 points a match.
  #176   Spotlight this post!
Unread 31-03-2010, 16:04
Gaurav27's Avatar
Gaurav Bhatt
I took my compiled database with entries from weeks 1 to 4 and created a pdf. My excel file was too big to upload.
The attached file includes all 1850 entries, sorted by OPR.
  #177   Spotlight this post!
Unread 04-03-2011, 11:22
Bongle's Avatar
Hooray, looks like this sucker still works, 3 years later! Big thanks to FIRST for not updating their scoring formatting.
I'll see about updating the regional list to the 2011 version tonight.
For those that don't want to read the whole thread, here is the latest version:
http://www.chiefdelphi.com/forums/at...2&d=1269426199
  #178   Spotlight this post!
Unread 04-03-2011, 13:42
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Bongle, what are the chances you could put this into a web app, hosted on a free server like google apps? That way we could get to it from our mobile devices, web browsers at work (many companies use proxies that prevent this .exe from working), and public computers that have paranoid IT infrastructure.
2017 Scoring Model
CAD Library | GitHub
  #179   Spotlight this post!
Unread 04-03-2011, 13:58
Bongle's Avatar
Given that my expertise is in C++, the chances of me personally doing it are very slim. The best I could do would be a java applet embedded in a web page.
  #180   Spotlight this post!
Unread 10-03-2011, 19:24
Best Available Data
FRC #1778 (Chill Out!)
This is probably a stupid question.
If we do >results.csv when we enter a query, where does this text document get saved? I can't seem to find it.
Thanks!
Offensive Power Ranking Calculations Greg Marra General Forum 4 18-03-2009 22:03
Offensive Power Rankings for 2008 Bongle General Forum 166 18-05-2008 15:05
Offensive+Defensive Power Rankings BornaE General Forum 4 05-04-2008 01:33
2006 Offensive Power Ratings sw293 General Forum 16 10-05-2006 17:04
(CURIE) Let's make this Easy for all of us. [scouting] 157#1Driver Championship Event 13 22-04-2002 08:56
