Go to Post Finally!!! I love hugs. - Eugenia Gabrielov [more]
Unread 31-03-2010, 11:40
Egg 3141592654's Avatar
Egg 3141592654 Egg 3141592654 is offline
Now a mentor, always a student
FRC #0810 (Mechanical Bulls)
Egg 3141592654 is on a distinguished road
Parallelism in Java
I am trying to move our team into a team that doesn't use the labview crutch anymore, and because i know OOP in java, it should be easy to mentor the younger teammates. I am recoding the robot from this year and it has a parallel periodic task. Do i create a new class and start a run method which would be created in the robotInit, or do i do something else.
On a side note, why does Netbeans 6.8 not have the FRC logo in the toolbar, while 6.7 does?
"The answers to the book of life are not found in the back." Charlie Brown
Software Mentor - Team Apex Robotics 5803
Lead Programmer - Team 810 Mechanical Bulls '09-'11
Unread 31-03-2010, 12:54
FRC4ME FRC4ME is offline
FRC #0339
FRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant future
Re: Parallelism in Java
Create a class that implements interface Runnable, like this:
public class MyTask implements Runnable {
    public void run () {
        // Do stuff in here
Then, in the main robot class, create a thread:
public Thread myThread = new Thread(new MyTask());
Start the thread in robotInit():
myThread.start(); // Will call MyTask.run() in a separate task
I think this is what you were thinking of already, no?
Go directly to queue. Do not pass pit.
Unread 31-03-2010, 13:12
Jared Russell's Avatar
Taking a year (mostly) off
You should also look at the documentation for a TimerTask in the JavaDocs.
Unread 01-04-2010, 08:46
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
Netbeans 6.8 show the FRC logo in 6.8 also. You probably need to reinstall the FRC modules after upgrading.
Unread 01-04-2010, 17:21
Yes, that is what i was initially thinking, minus the "implements Runable" part. Thank you.
As for the netbeans 6.8 not showing the FRC logo, it says that there is no jar file found. Is that jar file found in something else besides the 5 primary modules, and could manually installing these modules one at a time create an issue with this?
Java Tutorial...? tomy Java 2 11-02-2010 21:15
Java Questions andrewmerrill Java 6 14-12-2009 11:08
Java team1512 Java 2 21-10-2009 06:36
Java vs. C++ nickmagus Programming 3 05-09-2009 19:23
**FIRST EMAIL**/Java and Orbit Balls *****JAVA DISCUSSION*** Pjohn1959 Programming 37 31-08-2009 15:55
