Re: Repair of 2007 Victor 884
I think per <R60> it wasn't legal as soon as the case was opened.
I'm with you there Joe. "shall not be tampered with, modified, or adjusted in any way (tampering includes drilling, cutting, machining, gluing, rewiring, disassembling, etc.) " Seems clear that disassembling for home repair makes your 884 a practice controller even if replacing with OEM parts. So we really might be better off getting a certified repair and saving a few bucks there if the competition supply is getting low.
![]() Chris, If you have blown FET’s on your Victors, we generally don’t attempt to repair them. There are parts that have been compromised beyond just the FET’s and the cost becomes more to repair than to replace. Regards, Tom Watson VEX Robotics (903) 453-0820 |
Has anyone actually successfully repaired one? It seems there are large copper busses in the middle of the board, which sink all the heat away when trying to clear the through-holes. After giving this a try, I now know why IFI doesn't bother repairing any.
What replacement FETs did you decide on? |
It depends on the damage. If just one FET or two are bad, the cost to replace probably justifies the repair. Common thinking is that anything beyond a simple FET failure has likely stressed other components to the point of being unreliable in the future. I have had success with larger Weller tips using Mike Betts' method. However, I heat only the pin and remove it when the solder melts. Then I clean the hole using solder sucker rather than the wick. If one of the holes is still clogged, then I simply heat the new transistor pin as I insert it. |
| Victor 884 Issues | BHS Bucs | Electrical | 3 | 01-02-2008 15:10 |
| Victor 884 | Devo1098 | Electrical | 6 | 29-06-2007 07:51 |
| Victor 884 problem | Gal Longin | Control System | 11 | 26-01-2005 00:47 |
| Victor 884 | Kevin Ray | General Forum | 25 | 28-01-2003 15:02 |
| Victor 884 | Gary Bonner | Technical Discussion | 4 | 14-01-2002 08:10 |
