Go to Post In most cases on FIRST robots, we have more material than in we need in some places and less than we need in others. That single phenomenon is the leading cause of robot failures. - Paul Copioli [more]
Unread 31-03-2010, 15:09
vamfun vamfun is offline
Mentor :Contol System Engineer
AKA: Chris
FRC #0599 (Robodox)
vamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of light
Send a message via AIM to vamfun
Re: Repair of 2007 Victor 884
Originally Posted by Joe Ross View Post
I think per <R60> it wasn't legal as soon as the case was opened.
I'm with you there Joe. "shall not be tampered with, modified, or adjusted in any way (tampering includes drilling, cutting, machining, gluing, rewiring, disassembling, etc.) " Seems clear that disassembling for home repair makes your 884 a practice controller even if replacing with OEM parts. So we really might be better off getting a certified repair and saving a few bucks there if the competition supply is getting low.
Unread 27-04-2010, 16:34
AKA: Chris
FRC #0599 (Robodox)
Email response from IFI. So much for a certified repair
Chris,
If you have blown FET’s on your Victors, we generally don’t attempt to repair them. There are parts that have been compromised beyond just the FET’s and the cost becomes more to repair than to replace.
Regards,
Tom Watson
VEX Robotics
(903) 453-0820
Unread 03-06-2010, 00:37
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Has anyone actually successfully repaired one? It seems there are large copper busses in the middle of the board, which sink all the heat away when trying to clear the through-holes. After giving this a try, I now know why IFI doesn't bother repairing any.
Unread 03-06-2010, 01:45
AKA: Chris
FRC #0599 (Robodox)
Take a look at this http://www.chiefdelphi.com/forums/sh...4&postcount=31
What replacement FETs did you decide on?
Unread 03-06-2010, 08:18
Sandy,
It depends on the damage. If just one FET or two are bad, the cost to replace probably justifies the repair. Common thinking is that anything beyond a simple FET failure has likely stressed other components to the point of being unreliable in the future.
I have had success with larger Weller tips using Mike Betts' method. However, I heat only the pin and remove it when the solder melts. Then I clean the hole using solder sucker rather than the wick. If one of the holes is still clogged, then I simply heat the new transistor pin as I insert it.
Victor 884 Issues BHS Bucs Electrical 3 01-02-2008 15:10
Victor 884 Devo1098 Electrical 6 29-06-2007 07:51
Victor 884 problem Gal Longin Control System 11 26-01-2005 00:47
Victor 884 Kevin Ray General Forum 25 28-01-2003 15:02
Victor 884 Gary Bonner Technical Discussion 4 14-01-2002 08:10
