Go to Post it made me proud to be a part of FIRST. - Libby K [more]
Unread 31-03-2010, 15:49
EricWilliams EricWilliams is offline
FRC #2039 (Rockford Robotics)
EricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of light
Re: Question about a rule
Originally Posted by Alan Anderson View Post
The Dashboard is for display only. It has no way of communicating information back to the robot.
DIO values come from (or go to) pins on the Digital Sidecar on the robot. You can read (or write) them at any time without constraint. They will work whether the robot is in auto or teleop, and whether it is enabled or disabled.
The Driver Station software and Dashboard software are different. The bottom (smaller) window is the Driver Station software, and is REQUIRED to run during matches. The Dashboard is not necessary and can be replaced with custom software.
The Driver Station software has a Virtual DIO panel that is not read only. These are buttons that can be toggled by pressing on them. These can be set while the robot is DISABLED, and will remain in their state when the robot changes to Autonomous ENABLED. This means you can effectively use these Virtual DIO (not Read Only) as an autonomous mode selector.
These inputs do not come from the Digital Side Car and are read through a separate VI in the WPILib Dashboard palette.
Good luck!
About the new rules-about the updated Rule <G09> aten Rules/Strategy 1 13-01-2007 13:20
question about the corner-block rule Nimmy Rules/Strategy 15 18-01-2006 08:35
Question about rule <R26> --> Colours Bryan D Rules/Strategy 6 02-02-2005 16:09
question about the animation rule brokenleftthumb 3D Animation and Competition 13 22-02-2003 22:30
Rule Question about Big Ball... archiver 2001 3 24-06-2002 01:43
