read joystick without cRIO attached?
Is it possible, with the 2010 FRC LabVIEW installation, to create a simple VI that will read a USB joystick and display the x and y axis output on a front-panel indicator, without having a cRIO attached?
Our programmer tried for an hour to do this but couldn't get it to work. He says it works fine when the cRIO is attached. There must be a simple solution to this, no ? ~ |
Re: read joystick without cRIO attached?
Yes it is possible, but not with the FIRST Library. Go to Connectivity->Input Devices.
Thank you Joe. Greatly appreciated. I phoned your answer to the programmer and he was able to get it working. (He is working on some new ideas in the hotel room tonight).
| Joystick Read modification to breakout joystick buttons | sparks-1784 | NI LabVIEW | 2 | 02-03-2010 14:54 |
| Joystick Read VI and Passing Variables to the Control | Stealth | NI LabVIEW | 3 | 24-01-2010 12:59 |
| Axis camera without the cRIO | CrazyCarl461 | NI LabVIEW | 12 | 17-01-2009 10:53 |
| pic: 1741 and 45 overly attached | Bruce Newendorp | Extra Discussion | 5 | 03-03-2008 19:13 |
| Getting attached to your robot | Jherbie53 | General Forum | 13 | 02-03-2008 14:42 |
